Subwoofer?
Old Jul 11, 2020 | 10:03 PM
cpobst's Avatar
cpobst
Subwoofer?
Well I replaced all my speakers now I feel like I need better lows to fill it in. Curious how others have added a sub? I've got the 7 speaker system w/o Nav. Was wondering if I could fit one under the rear seat.
Old Jul 11, 2020 | 11:15 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Under the seat or behind it, there are many options. I'd help ya out with some links, but I'm on my phone right now
I'm about to install one under my rear seat soon...
Old Jul 11, 2020 | 11:19 PM
cpobst's Avatar
cpobst
Well the behind the seat options I saw said that the seat had to be moved forward a few inches. That's not something I want to do so I'd like to find something under seat that's worthwhile. Searching "subwoofer" in this specific forum returned no results.
Old Jul 11, 2020 | 11:50 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Back on a computer now...
I haven't heard of anyone having to move their seat forward, though I'm sure the manufacturers recommend it for full use of the rear seat function while using the sub. Most people say when lifting up the seat bottom, the back of the seat will touch, but in seating position, and with the back of the seat folded down, there is no clearance issue. It's a good idea to cut the rear carpet out around the box to get another inch or so of room though.
https://www.ford-trucks.com/forums/1...l#post16816159
https://www.ford-trucks.com/forums/1...l#post16796080
https://www.ford-trucks.com/forums/1...-the-seat.html
https://www.ford-trucks.com/forums/1...be-sat-in.html
https://www.ford-trucks.com/forums/1...ade-build.html
And this is the BIG thread with a lot of setups throughout it:
https://www.ford-trucks.com/forums/1...ck-stereo.html
Old Jul 12, 2020 | 03:41 AM
34SF's Avatar
34SF
https://www.ford-trucks.com/forums/1...l#post19373981
https://www.ford-trucks.com/forums/1...-platinum.html
https://www.ford-trucks.com/forums/1...d-o-sucks.html
https://www.ford-trucks.com/forums/1...-speakers.html
https://www.ford-trucks.com/forums/1...pgrades-2.html
Old Jul 12, 2020 | 06:48 AM
Bronkxone's Avatar
Bronkxone
I put a JL micro sub that had 2 8" drivers behind the rear seat. The only catch was the seat now only lifts up about 80% vs normal all the way up. I am fine with it as I can get to anything under the seat no issue.
Old Jul 12, 2020 | 08:54 AM
cpobst's Avatar
cpobst
Thanks for the links and ideas. I guess I haven't figured out the secret to this sites search function because I sure couldn't find anything.
Old Jul 12, 2020 | 05:47 PM
System's Avatar
System
Prolocutor
I would highly suggest MTI for behind the seat if you don't want to loose your under seat storage. If you don't mind loosing the storage under the seat, JL Audio's Steathbox is a winner for sure. But I wanted to retain it so I went MTI. You can go single or dual driver. I would recommend calling them before ordering as they always seem to have a promo code available for the asking. https://mtiacoustics.com/product/for...eat-enclosure/
Old Jul 15, 2020 | 10:28 AM
cutigers52's Avatar
cutigers52
I had a sub and and amp put behind the drivers side rear seat only to find out that after the install I could no longer raise the seat which is disappointing. How are people moving the seat up?
Old Jul 15, 2020 | 10:39 AM
System's Avatar
System
Prolocutor
The MTI is thin enough that you can still lock the bottom seat in the up position. Many brands aren't narrow enough though.
Old Jul 15, 2020 | 11:59 AM
Tricon's Avatar
Tricon
I put 2 x 10s behind the rear seats, had to build my own box, but I got a 1.1 cu ft box back there and can still lift up my seats. Perfect for my Infiniti subs that wanted .55 sealed space per sub.
VONxRUBENxLA
Dec 2, 2011 11:29 AM
Chris-R
Sep 13, 2007 01:48 PM
lethalinjection
Feb 21, 2006 01:53 PM
Rod it and Haul it
Jun 1, 2004 05:43 PM
stealth1
Mar 29, 2004 05:33 PM
