Checking timing gears
Old Jul 11, 2020 | 07:43 PM
ynot321AB1's Avatar
ynot321AB1
I am about to take the distributor out and take off the timing gear cover to check them. My question is, if I cannot put a screwdriver into the cylinder to determine when #1 cylinder is at the top, how do I judge when to restab the distributor? Working on a '51 239.
Old Jul 11, 2020 | 09:46 PM
38 coupe's Avatar
38 coupe
The timing cover has a pointer on it that lines up with a bump on the crank pulley at top dead center (TDC). Pull your #1 spark plug and hold your thumb over the hole while cranking the engine. You will feel air pushing your thumb up on the compression stroke. By hand rotate the crank to line the pointer up with the pulley bump and you are at #1 TDC. If you are still running points you can then static time it and be done.
Old Jul 11, 2020 | 10:07 PM
ynot321AB1's Avatar
ynot321AB1
Please to excuse my ignorance but I do not understand static time something.
Old Jul 12, 2020 | 12:10 AM
Steve's Avatar
Steve
Static timing involves setting the timing with the engine off as described. Get the #1 piston to TDC, drop in the distributor so the rotor will coincide with the number one plug wire on the cap, then rotate the distributor body until the points just open. That gets you close enough to start the engine, then you can adjust while running.
Old Jul 12, 2020 | 12:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Why are you going to check the timing gears, if the distributor is rotating as you previously posted? The gears can't skip a tooth like a chain or belt.
Tallguy44
May 30, 2018 01:27 PM
Bigwalt619
Sep 28, 2015 12:02 AM
ramtoo
21
Dec 27, 2005 10:31 PM
myst
May 9, 2004 10:09 PM
OrionsIce
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 28, 2003 03:16 PM
