Transmission shift question
Old Jul 11, 2020 | 06:39 PM
MannyC750's Avatar
MannyC750
Friend has 1937 ford sedan he is working on with a newer chebby
350 engine and automatic tranny. When he putts it in second gear the car goes in reverse. What's up FTE guru's.
Old Jul 12, 2020 | 11:42 AM
EBEAR's Avatar
EBEAR
Do the other gears work properly ? I would get the tires off the ground , unhook the linkage and shift it by hand to determine if they all work and where park is . Did he make his own linkage or use an existing setup , floor shift or column ? My first guess is that it is shifting the wrong direction ie. where he thinks park is actually 1st then the next notch would be second not reverse . If it's not a linkage problem then it's internal .
Old Jul 12, 2020 | 12:05 PM
MannyC750's Avatar
MannyC750
Thanks EB, I'll tell him.
Old Jul 12, 2020 | 03:12 PM
1956_F100's Avatar
1956_F100
Is the trans in park when the shifter is in park? What kind of shifter is in the car? There are shifters for forward and reverse valve bodies. Did somebody install the wrong type of shifter? Is the trans fluid full? Low trans fluid will cause all sorts of strange issues.
Old Jul 12, 2020 | 04:14 PM
MannyC750's Avatar
MannyC750
Thanks 56, I'll let him know after I get home from work.
Kjvitte
Feb 20, 2017 03:39 PM
Kingslayer
2009 - 2014 F150
Feb 13, 2015 10:29 AM
4trax
1997 - 2003 F150
13
Jun 4, 2008 11:49 PM
bigbears
Oct 31, 2000 09:44 PM
