Sponsored by: Real Truck
Difficult Shifting F-250SD
Old Oct 29, 2000 | 11:54 PM
bigbears's Avatar
bigbears
I have a 1999 F250SD 4X4 reg cab long box with the 5.4L manual transmission and occasionally I have difficuly getting the truck into 5th gear and reverse. To get it into reverse sometimes I have to drive forward a bit before it will shift into gear. I was wondering if anyone else has had this problem?
Old Oct 30, 2000 | 10:25 PM
Roger_B's Avatar
Roger_B
I have an 00' F250 5.4L 5sp 4.10LS
Sometimes to shift into reverse, I first have to shift into 2nd, then goto directly to reverse. I've had other tranny's that were the same way, somehow the shift to 2nd, sync'd stuff up just right to allow an easy slide into R.
Same story when shifting to 1st, (sometimes easier if I shift to 2nd first).
When going up through the gears:
1->2: pretty notchy. hard to hit this gate right, but likely because there really wide gap in ratio from 1->2, and its way easy to overrev in 1st.
(I rarely use 1st anyway.. Only when I tow).
2->3: a little notchy, but its a truck tranny, not a sports car. (I normally start in 2nd)
3->4: smooth, every time
4->5: smooth, every time
Old Oct 31, 2000 | 09:44 PM
DIESELSITE's Avatar
DIESELSITE
Former Vendor
