Transfer Case compatibility?
Old Jul 10, 2020 | 01:52 PM
1stexcursion17's Avatar
1stexcursion17
I am looking to upgrade my 2000 2wd to 4wd using axles out of a 05 F-250. My current concern is whether or not the transfer case out of the 05 (manual transfer) is compatible with my transmission? I know a 4wd output will need to be added to my transmission. Your knowledge on this is greatly appreciated.
Old Jul 10, 2020 | 03:19 PM
EXSwap's Avatar
EXSwap
I suppose it depends on which transmissions you have (because I'm not sure what the output of a 4R looks like). To my knowledge, the NP271 was used 1999-2016 and so were the NP273's, which would make them the same round 6 bolt pattern. Another thing you may have to change is the input shaft to the transfer case as I'm not sure of the spline count difference between the 4R and 5R.
Old Jul 10, 2020 | 03:44 PM
1stexcursion17
Thank you for the information. At least I have direction now.
Seedguy99
Jan 18, 2020 08:08 AM
rdmobile
Dec 1, 2013 10:37 PM
itsnotanova
Nov 8, 2009 05:11 PM
Katmandu
Nov 2, 2005 09:46 PM
Tex311
Bronco II
Jan 5, 2004 08:30 PM
