The mirror would have to be replaced. Check the child lock on the door latch. There is a little lever that will stop the door from being opened from the inside.
Are you talking the rear view mirror? If so lots of other ford vehicles of that time frame have the same mirror and swap right in. I got mine from a freestyle in a junkyard for $10
Just to make sure we are on the same page are you saying the door will open with the outside handle but not the inside? If so when you open the door there is a little lever by the latch that moves. It is only 1/4"x 1/4".
If it isn't the child safety lock then you will probably have to remove the door panel and look inside. A rod has come off, the handle is broken, or one of the rod retainers has broken.
