neutral switch
Old Jul 9, 2020 | 06:42 PM
Fireater1968's Avatar
Fireater1968
neutral switch
in 79 it was on transmission. i know this. in 76 it was on column. Im using a transmission form a 1976 f150 and want to install the neutral switch on transmission. the bolts holes are there but i dont see grooves for the switch on selector shaft area.
advice anyone?
Old Jul 10, 2020 | 08:48 AM
headloct's Avatar
headloct
79 truck? Assuming they're both C6's.,just switch the shift levers.Not that hard of a job with both transmissions out of the vehicles.You will have to remove the pan and the valve body.The nut holding the lever is on the inside.
Old Jul 10, 2020 | 08:56 AM
Fireater1968
crap. i dont have donor transmission
now i need to find that part .. sigh
Old Jul 10, 2020 | 12:16 PM
mark a.'s Avatar
mark a.
You can carefully grind that notch into your old one.
Old Jul 10, 2020 | 12:19 PM
beartracks's Avatar
beartracks
I believe the mounting of the switch went from the bottom of the column to the tranny in mid 77
Old Jul 10, 2020 | 12:43 PM
Fireater1968
yah I would try that. But I need a good photo for clocking the notches. I have no starting point.
Old Jul 10, 2020 | 02:21 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Yea, sucked trying to find that piece when I decided to swap to a tilt column in my 1973. I ended up spending a pretty penny for a rebuildable core and using the shaft out of it. Bright side I have it now.
Old Jul 11, 2020 | 08:12 AM
5851a's Avatar
5851a
I didn't know they ever made a arm without the groove. Why would Ford drill and tap all the cases for the switch and then make 2 different arms? I'm just curious.
Old Jul 11, 2020 | 08:13 AM
Fireater1968
no kidding
Old Jul 11, 2020 | 04:54 PM
5851a's Avatar
5851a
Ok, there is an alignment hole on the switch, rotate the center of the switch until you are able to insert a small nail or something about 1/16 inch through the hole. When the switch is centered you can see where the groove needs to be if you index the switch to the mounting holes. I cannot for the life of me remember what gear transmission need to be in. I believe it's neutral. Hopefully someone with a shop manual will be able to tell you.
Old Jul 11, 2020 | 05:31 PM
Fireater1968
oh? That's good info thanks. I do have shop manuals it may be in there.
Old Jul 12, 2020 | 01:10 AM
1TonBasecamp's Avatar
1TonBasecamp
Sounds like a running change. They started making the cases ready for the switch, but were not ready to change the wiring harness and steering columns just yet. A lot going on in the mid to late seventies!
paul
Old Jul 12, 2020 | 09:11 AM
Fireater1968
paul
no..they had it on transmission years before on the bumpsides and galaxies and other cars. No idea why it got moved
werksvan
Sep 26, 2018 11:54 AM
jville
May 19, 2009 05:29 PM
The67Beast
Mar 10, 2007 01:23 PM
RICHMC54
Dec 5, 2004 05:18 AM
pg32
Bronco II
Feb 22, 2004 02:50 PM
