passenger door lock problem
Old Oct 21, 2007 | 07:37 PM
bigdog55's Avatar
bigdog55
I have just syarted having a problem with the passenger door locks not totally responding to the controls.. When I push the button on the fob,they will pop part of the way up and then when I let up on the button,they go back to the lock position..It does the same thing with the door controllerAfter several tries they will finally unlock,but the next time they are unlocked the same thing happens....Is this a solenoid problem or what???
Old Oct 21, 2007 | 08:36 PM
manglass's Avatar
manglass
A lot of folks have had to replace the power door lock actuators (lots of posts about this) but I was able to get away with taking the door panel off (really easy) and lubing the latch assembly from the inside. A good dousing w/WD-40 worked wonders. You might try that before you start replacing parts.
Lou
Old Oct 22, 2007 | 01:26 AM
afreemanmd's Avatar
afreemanmd
if you are looking for door lock replacement procedures, they are in the stickies at the top of the excursion main page.
Ive done my driver door and rear hatch, and and now one of the back doors is acting up, so ill have to do it too >_<
Isaac
Old Oct 23, 2007 | 11:44 PM
malmz's Avatar
malmz
And order 5 replacements... once you are in the swing of it, it goes quicker and they will all fail eventually anyway. Start with the right front door, it's easy to see what is going on in there since some of the other doors you need to do blind.
