Engine Code Help?
Old Oct 19, 2003 | 10:41 AM
75HighboyF250's Avatar
75HighboyF250
Question Engine Code Help?
Ok Guys...........
I think I have read every thread on this forum about engines and codes. I am still missing the answer on my engine. I was told that is was a 390 in the truck. After reading a lot of threads related to these things it appears that there is a lot of mystery as to the 390 360 facts. After using a decoder for the VIN it indicates that the truck left the factory in Michigan with a 360 2 barrel carb. It seems that the casting numbers most people ask for are the ones below the oil filter on the block. Mine are as a follows.............A large E with the 2k28 below it. Does anyone have any idea what motor I have? 360 or 390?
Thanks!
Old Oct 19, 2003 | 01:19 PM
Mil1ion's Avatar
Mil1ion
Hi There welcome to FTE!
The 360 was designed for a Truck But they also had 390's in them.
This would constitute a T in the casting number of said part.
ie - D2TE-9425-A
The 390's were usually 4 bbl in Trucks.
The casting numbers you posted are only Date of the casting of that part, in your case (2k28) was October 28/1972.
The only way to tell the difference is to measure the stroke.
On the exterior they look alike.
The numbers you will find on the :
heads, Block (????-6015- ? ),Intake (????-9425-?) & exhaust manifolds.
If you find a A or an O as the 3rd digit, that engine was designed for a car but used in a truck also.
Old Oct 19, 2003 | 05:18 PM
75HighboyF250
Thanks for the info................
Pretty much rules out the factory motor question then. I believe I will discover it is a 390. Although I did the VIN decoder thing and according to that it left the plant with a 360? But, like so many of these trucks, the running gear has changed to many times to count in most cases.
Fellenz
23
Dec 8, 2014 04:51 PM
chinoz71
Feb 22, 2014 10:44 AM
73F100*8Mile
Sep 15, 2005 09:56 PM
boomer202
Jan 1, 2004 04:39 AM
mforren
May 8, 2000 09:49 PM
