Sponsored by: Real Truck
7.3 acceleration problem
Old Jul 6, 2020 | 06:01 PM
jamesj's Avatar
jamesj
I also posted this in the EXcursion Forum
I have 2000 excursion with 7.3 engine odometer is 177,000. Each time I tried to accelerate there is delay and going uphill is a struggle, first notice this condition in 7/2017. Turbo boost gauge shows 5psi when going uphill. On 11/2017 check engine light came on errors P0678, P0676, P0674 and P0672, replaced plug control module I erased the error code never showed up again. On 1/2016 check engine light on, error code P1670, charged batteries erased error code never shows up again. . When I bought this in 2003 (used) I had no problem accelerating. I change oil and filter, and fuel/water separator every 5K.. Reolace air filter at 172928 miles. 7/24/2017, On 10/2012 mileage 155660 transmission fluid flushed and replaced fluid. by dealer. I used to have Predator setting to 60HP but removed it on 9/2010 due to incorrect Average GPM reading.
What is causing this engine to behave like this? Any suggestions? Let me know if additional info is needed.
Thanks,
James
jamesj
Jul 11, 2020 06:42 PM
klifter
6.4L Power Stroke Diesel
Aug 6, 2010 05:58 PM
Tryan7
May 23, 2007 09:31 PM
EX GM GUY
Jul 18, 2003 09:25 PM
