360 Camera Without Tailgate
Old Jul 6, 2020 | 05:53 AM
Drothgeb's Avatar
Drothgeb
Like a lot of you, I’ve removed my tailgate for hauling a camper. I did get the additional camera for the camper, and it works well when the camper is on. But when the camper is off, I miss having the 360 camera, especially when hitching a trailer. I didn’t want to pull the original camera from the tailgate, so I looked at aftermarket solutions, but $400+ seemed pretty pricey.
After some searching, I found the part number for the original camera and the type of connector connecting it. After that, I turned to eBay. Found a new in box camera for $160 and brown Fakra connectors for RG58 coax for $15. For an enclosure, there was already a piece of plastic trim on the rear of the truck that seem to almost be made for it, so I used it. Drilled a hole and mounted the camera with hot glue for now.
It’s best to mount the camera as high as possible, so for now mine is mounted to the camper platform. If you don’t have a platform, it can be mounted just below the bed. It works well. The only issue is, the image with the 360 view is a little wonky where the rear image is stitched to the sides due the camera being lower and part of the bumper is visible. Otherwise, it’s good. Here’s a couple of pics.
Old Jul 6, 2020 | 06:52 AM
crewzer's Avatar
crewzer
Cool
Well, that’s a pretty cool work-around!
Thanks for posting,
Jim / crewzer
Old Jul 6, 2020 | 12:41 PM
RV_Tech's Avatar
RV_Tech
Smart thinking!
Steve
Old Jul 6, 2020 | 11:56 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Nice! I'm sure a lot of folks will get good use out of this thread!
Old Jul 7, 2020 | 06:00 PM
Sasha4's Avatar
Sasha4
I did something like this but installed it on my camper so I can use the factory screen to back-up. Mine unfortunately doesn't work with the 360 but can be accessed with the Aux button
Old Jul 7, 2020 | 07:39 PM
Drothgeb's Avatar
Drothgeb
I have one on the camper that plugs into the 12 pin connector too. It’s nice to be able to switch back and forth between cameras. I have a toolbox on the truck, so I can’t see into the bed or the bottom of the camper when I’m loading it. But, I have a center line drawn on the bottom edge of the camper and use the 360 camera to align it when loading. Once it’s loaded, I switch over to the camera on the camper.
Old Jul 8, 2020 | 12:14 PM
WyoBull's Avatar
WyoBull
I like this idea a lot! I would have to be able to take it on and off easily as I take my tailgate off in early spring and then when I put the camper away after hunting season in the fall I put the tailgate back on.
Old Jul 13, 2020 | 09:27 AM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
That "piece of plastic trim" on my 2019 F-450, is mounted much closer to the bumper and has three amber marker lights on it? Weird?
Old Aug 2, 2020 | 05:19 AM
Drothgeb's Avatar
Drothgeb
Mine was originally mounted in the same place as yours, just didn’t have the lights in it.
Old Aug 2, 2020 | 08:56 AM
Wing Nut Bert's Avatar
Wing Nut Bert
Wow. That's very cool. I'm just thinking of going with a wireless camera and separate screen. But this would be pretty trick to do. I was wondering if anyone was able to use the rear view cam's to load if they were able to see the top edges of the bed well enough to see if they are centered. I'm thinking going to a new 350 dually crw cab is going to be a lot more difficult then loading my old GMC ext. cab. Though my old truck has a tapered bed so to make things difficult and tight anyway. But I just move a bit, hop out, look, adjust, move a bit more, and so on. Easier to do that then trying to figure out what my wife's random, epileptic seizure looking hand signals mean.....
Old Mar 13, 2024 | 03:50 AM
dutch71's Avatar
dutch71
@Drothgeb hi there. in my case I take the platform for the camper out. that plastic trim you say "it can be mounted just below the bed". any idea how to do that without having to drill holes?
BHPR
May 4, 2024 10:58 AM
PalouseSD
Aug 13, 2018 09:23 PM
munch18
Jun 23, 2016 06:27 AM
ZonaNavyStar
Jul 17, 2008 12:11 PM
76f350spercamprspeal
15
Jul 15, 2008 05:42 AM
