None of the circuits work? I have a plug in circuit tester that makes it easy to check all the functions. Much easier than using a test light and most RV dealers have them. Also there is a chassis ground on the inside of the frame back towards the fuel tank that comes out of the wiring harness going back to the plug. I would make sure that is still attached.
I am going to crawl around under there one the woman is done with me today! i have unplugged the harness before the plug getting nothing there , I will check the ground!
It was working before , have had several trailers hooked up and worked fine
had the brake and turn signals working the other day but now they don't even work
So i finally had the time early enough not to broil on the concrete, Dropped the spare and got to the ground on the rear harness, took it apart cleaned it up , put it back together!
Not only did it not help but now when i step in the brakes my radio lights dim, LMAO what have i done now!
Wife is at work today so i will pull the ole girl into the garage and run some tests
