Fan blower speed issues
Old Jul 3, 2020 | 02:25 PM
fishsqueezer's Avatar
fishsqueezer
94 f350 idi turbo, cclb 4x4
I'm having issues with my fan speed/blower controller. Reading through searched posts, I originally diagnosed the problem as a failed blower motor resistor. Only blew air on high (4 of 4 speed), no air movement on settings 1-3. Replaced resistor and good for last two months. It has now failed once again.
Another failed resistor? All grounds cleaned and secure. Just a bad new resistor? Dont want to just throw money at it, the last resistor was nearly $30. Any one brand/supplier better than others?? TIA
Old Jul 3, 2020 | 02:35 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes? Take it out, look at it and test it if not visibly bad.
Old Jul 3, 2020 | 05:16 PM
fishsqueezer
Waiting for cooler evening to test
Visibly bad, in that all of the resistor coils will have a visible break in them? Test each one for continuity?
Old Jul 3, 2020 | 06:41 PM
fishsqueezer
Thx for the help Solved
Answered my own question. Moved the truck to a nice shady spot (nearby Autozone parking lot has some amazing shade!), removed the resistor and found an obvious break in 2 resistor coils and failed continuity on the third. Purchased the correct, according to Ford mech on phone, 300*F resistor and installed new one. 4 speeds again!
Old Jul 4, 2020 | 04:39 PM
FuzzFace2's Avatar
FuzzFace2
There is a reason why they are installed in the HVAC box ..... air flow to keep it cool. I wonder if you have low air flow to this resister?
I know on the 80 - 86 trucks leaves & sticks come in thru the cowl and stack up on this HOT resistor and start a fire and once going is vary hard to put out as the fire is inside the HVAC box.
Again on the 80 - 86 trucks pull the blower motor and reach inside and you can pull out hand fulls of crap.
I also took shop air, 175 PSI, and blew it clean. Some dirt did come up the vents inside but small price to pay not to have a camp fire inside the truck.
Dave ----
keepnthepeace
Nov 20, 2010 06:58 PM
snoschu
Sep 2, 2009 07:55 PM
Madmike33
1983 - 2012 Ranger & B-Series
Oct 11, 2006 08:56 AM
koalamazed
Aerostar
Sep 28, 2004 05:00 PM
quarter
Dec 16, 2003 09:12 AM
