axle wt.
We need the same details for your 2015 F350 CrewCab.
More later,
Mim / crewzer
Reference material:
2010 Super Duty Body Builders Layout Book
2014 Super Duty Specs
2014 Super Duty Sales Brochure
I suspect the 2010 is not a 6.2, which, IIRC, was introduced for MY2011.
Based on the description and specs provided, the 2010 F350 appears to be an SRW SuperCab Shortbed 4x4 5.4 manual with 18” wheels and tires. Here are key base trim weight specs:
GVWR: 10600 lbs.
GAWR front: 4400 - 4800
GAWR rear: 7000
Max payload: 4090 (base trim, no options)
Curb weight: 6437
(full fuel tank, no driver or passengers, no accessories, cargo, or options)
CW front: 3687
CW back: 2750
The 2014 F350 appears to be a CrewCab shortbed 4x4 6.2 auto with 20” wheels and tires, and probably the optional snowplow package:
GVWR: 11300 lbs.
GAWR front: 4800 (max); 5600 with snowplow package
GAWR rear: 7000
Max payload: 4440 (base trim, no options)
Curb weight: 6955
CW front: 3980
CW back: 2975
Using just the base numbers, the 2014’s rear axle curb weight is 275 lbs. higher than the 2010. The Platinum trim weights more than the XLT, and they may be other options, so let’s allow for another 100 lbs. on the rear axle.
We’ve now reasonably accounted for 375 lbs. higher rear axle weight, which is pretty darn close to the 380 lbs. for which you are looking.
Bigger tires won’t increase your rear axle load capacity, as it’s probably limited by wheel load specs and/or rear spring specs.
Check to see if your 2014 has a rear stabilizer bar; many trucks with factory 20” wheels do not. A stabilizer bar (which will add more weight to the rear axle) is highly recommended when carrying a truck camper.
Pushing your camper a bit farther forward in the bed may be a good idea, as it will shift some load from the rear axle to the front.
HTH,
Jim / crewzer
We carry a 2019 Lance 855s on our 2019 F350 CCSB 6.2 4x2, and weight is a challenge. Here’s a list of things we’ve done to improve our weight-carrying-and-handling capability and keep our “fully-loaded-headin’-out-on-a-trip” weight down to about 11K lbs.
Our truck was special ordered to safely, reliably, and comfortably carry a medium-size truck camper. The build included Lariat Ultimate trim, The Chrome Package, lots of cameras, a 240A alternator, and the optional Camper Package, which added stiffer front springs and a rear stabilizer bar, but we passed on the heavy double moon roof.
We also passed on 4x4, but did order the optional 4.30 locking axle. 4x4 with larger tires would have increased the GVWR and payload due to the larger tires. I added the larger tires last year. I also installed Firestone air springs to help level the truck.
To reduce truck weight, I remove several items before loading the camper: bed mat (50 lbs.!), bed cleats, rear seat headrests, floor mat, and under-seat storage box. Of course, the tailgate with integrated step and grab bar come off.
To attach the camper to the truck, I installed Torklift tiedowns and turnbuckles. The rear tiedowns attach to the hitch, so that heavy item has to stay. However, I may look at removing the truck’s rear bumper when carrying the camper. I may also look at moving the spare tire to our crewcab’s back seat floor area.
To reduce camper weight, I removed the propane generator, the extra propane tank (38 lbs.!) and the drop-down bunk. The cabover queen mattress was replaced with a lighter and more comfortable product from Tuft & Needle / Amazon. We replaced our cast iron Dutch oven with an aluminum model. Our two zero-gravity chairs are stored in sleeves and place on the cabover bed for travel. I did add 2x 100 W solar modules on the rooftop luggage rack.
I replaced the camper’s two long front bumpers with shorter types that allowed me to locate the camper perhaps 1-1/2” further forward in the truck bed. We generally travel with little or no fresh water. If we need it, we fill the FW tank and water heater at/near our destination. We dump the GW and BW when we leave a site.
For a spare fridge, we carry an an electric cooler instead of an ice chest; it’s lighter when full.
Finally, we remove most personal items, tools, and supplies from the camper when we return home. Items that we actually use are stored to be loaded for the next trip. Things that we don’t use are used elsewhere at home, given away, or discarded. I’m getting better about my tools- and spares kit for the truck and camper.
In sum, we find that we can carry virtually everything that we want or need, and we can keep our weights in check. However, it takes a fair amount of effort and attention to detail.
HTH,
Jim / crewzer
