I know on these newer trucks the 7 way doesn't have power until the trailer module detects a trailer and you press the brakes. Has anyone found away around it? I would like to have a way to get 12 V power out of the 7 way on occasion without any trailer hooked up.
A benefit to the U/S solution is that you can easily configure #5 and #6 to “Always Hot” and then have power available from either switch without the engine running.
HTH,
Jim / crewzer
Excellent point, I’m either going to use up fitter or just a boring power point cigarette lighter plug.
