Trailer power
Old Dec 8, 2018 | 12:43 PM
Slackerme's Avatar
Slackerme
Trailer power
Ive got a 2018 350 Platnium
Has the integrated trailer brake contoller
I have power to the trailer when the truck it running
Wondering if there is a way to give constant power out back?
I tow a 24' enclosed snowmobile trailer and it would be nice when loading and unloading at night to be able to turn the loading lights and interior LED on without having to start the truck.
Mainly when we are just loading for the night and headed to the hotel.
No need to fire up the Diesel to run for 10 minutes
Old Dec 8, 2018 | 12:53 PM
RandyinTN's Avatar
RandyinTN
What happens when you have the ignition on in accessory mode?
Old Dec 8, 2018 | 01:06 PM
Slackerme's Avatar
Slackerme
Doesnt seem to work.
Only if its running.
But for my application when getting back to the trailer for the days ride.
I have no reason to even open the door to my truck.
Old Dec 8, 2018 | 03:54 PM
jbrnigan's Avatar
jbrnigan
Install a battery in the trailer and connect it to the 7 way, 12 volt to keep it charged.
Old Dec 8, 2018 | 03:56 PM
Mixerman90's Avatar
Mixerman90
Maybe tap into the bed lights? I know I can turn my bed lights on without the ignition on. They stay on for only about 10 minutes though.
Old Dec 8, 2018 | 03:57 PM
Slackerme's Avatar
Slackerme
There has to be a way to get it to be powered all the time
my last 3 fords did it
2010 250
2013 150
2014 350
Old Dec 8, 2018 | 04:05 PM
sdetweil's Avatar
sdetweil
yeh.. my 20 ft enclosed car hauler has a battery for interior lights and the breakaway brake controller..
sdetweil's Avatar
sdetweil
2010 250
2013 150
2014 350
my 08 and 12 duallys only had trailer power on run
Old Dec 8, 2018 | 04:09 PM
Slackerme's Avatar
Slackerme
Let me rephrase that
I would get power to trailer if
I opened a door on the truck or
hit the unlock bottom on remote
which would only light them up for 20 seconds or so but there has to be a way to get power without truck running
Old Dec 8, 2018 | 04:53 PM
rob40cal's Avatar
rob40cal
Yes you can.
There is a thread some where, you can jump a wire on the trailer brake control module under the dash.
search Putco's brake light install.
I did it to my truck works just fine.
Rob
Old Dec 8, 2018 | 05:06 PM
jbrnigan's Avatar
jbrnigan
Originally Posted by rob40cal
Yes you can.
search Putco's brake light install. I did it to my truck works just fine.
Rob
Here's the link, I'd still install a battery - in the event you want 12 volts and the truck is not connected
File Type: pdf
Flathead2755
Jul 6, 2023 09:07 AM
skibuoy
All Things Towing
Jun 3, 2019 07:34 AM
Stephen C
2015 - 2020 F150
Apr 12, 2019 06:31 PM
JD'sBigredv10
Nov 18, 2018 09:47 AM
adgjqetuo
Sep 25, 2018 11:08 AM
