e99 oil leak
Old Jun 29, 2020 | 01:05 AM
MeanGreen99's Avatar
MeanGreen99
e99 oil leak
Hello,
recently I did some work to the truck that required me to remove the turbo and pedestal. When I finished.... obviously there is now a terrible leak from either the pedestal or the turbo where it meets the pedestal. This is also the EBPV... I replaced the o rings when I noticed the garden hose of oil leaking. changed the O rings and the leak still remains (less of a leak but still terrible). Hoping I can find some help here. Also before I did this work the truck didn't leak a drop of oil.
Thanks
Old Jun 29, 2020 | 01:52 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Which o rings did you replace, the turbo seals or the EBPV?
It's pretty easy to dislodge the turbo o rings when installing the turbo, so that's my first guess. Sucks to do that job again, sorry. Keep the turbo o rings in place with a dab of petroleum jelly during install.
Also mind the clamp on the collector to the turbo, easy to misalign and get an exhaust leak there.
Old Jun 29, 2020 | 08:45 AM
AllaboutMPG's Avatar
AllaboutMPG
^^^^^^^^^^^^^^^ what he said. Will need to do it again unfortunately. Get good quality orings for both the pedestal and the turbo, make sure all surfaces are clean and use some assy lube to keep orings in place during install. torque bolts well.
https://www.dieselorings.com/1999-20...kit-99-03.html
https://www.riffraffdiesel.com/turbo...all-kit-99-03/
Cell's
May 6, 2015 10:57 PM
FFSmith
Jul 6, 2010 12:37 PM
xbigbuckleyx
Jan 14, 2010 09:55 PM
ccorrell77
Dec 7, 2005 03:20 PM
