AC Questions
Old Jun 27, 2020 | 09:33 AM
Nick Migues's Avatar
Nick Migues
AC Questions
Howdy folks, I’m back again. I have a 94 F150 Flare side with the 5.0 motor, and I’m trying to get the AC working in this thing. When I bought the truck, it had been wrecked on the passenger side so first thing I did was replace the blower motor/evap core housing. I then tried to charge it, and discovered it had a pretty good leak in the drier/accumulator. I replaced the accumulator, and tried charging it again, and I noticed the compressor clutch wasn’t kicking on, so I jumped the clutch cycling switch to see if it would come on, which it did, and went ahead and charged it up to about 32 PSI. When I plugged the switch back in, the clutch went back to not engaging, so I checked to see if it needed Freon again, which it read it had 95 PSI now. So I went ahead and changed the clutch cycling switch and it still won’t kick the compressor on. I’ve also checked the fuse and it’s good. What else could be causing the compressor to not kick on? Thanks.
Old Jun 27, 2020 | 09:42 AM
jas88's Avatar
jas88
If you jump the switch at the accumulator, and the clutch engages, then either the switch is bad or you are still low on refrigerant. Your 1994 model should take R134a.
Old Jun 27, 2020 | 10:07 AM
Nick Migues
Okay so now I’ve added some, I’ve got about 43-45 pounds in it, and with the clutch cycling switch plugged in it comes on for about a second, and then shuts off for like 10 seconds. When the clutch comes on it says it has about 20 PSI in it, and the air isn’t very cold. Should I keep adding?
With the engine off it shows the system has 60 PSI
Old Jun 27, 2020 | 01:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Did you draw down the system with a vacuum pump and make sure there aren’t any leaks? How much have you put in the system?
Old Jun 27, 2020 | 08:39 PM
Bubba Jones's Avatar
Bubba Jones
I believe these systems take about 38oz of R-134a when empty. However, like MyFordtrucks was asking, vacuuming down the system is very important before adding anything. You want the system fully vacuumed down before you add any refrigerant.
If you did vacuum the system down, then you are relatively safe purchasing four of the 12oz cans and just filling through the low pressure side near the accumulator while using about 1/2 of the 4th can (because there is going to be some loss between switching cans.) If you didn't vacuum it down, I'd highly recommend having it vacuumed down and leak tested before trying some more.
Amazon sells some manifold gauge sets that are relatively cheap, and harbor freight sells a vacuum pump for 10 dollars that works with an air compressor. So if you have an air compressor handy, you don't have to spend too much money to be able to pull a vacuum on the system. If you weren't able to vacuum the system down and had it open, there is a good chance you system won't last too long and won't operate correctly.
Old Jun 27, 2020 | 10:06 PM
matt167's Avatar
matt167
If you have a decent air compressor. Harbor Freight has everything you need to correctly service A/C except the can adapters which some auto parts stores have for $20ish
pecanflyboy
Nov 5, 2012 12:33 PM
michaelbrainardatwor
Dec 9, 2007 08:01 AM
JefFZ6
Jul 2, 2007 09:21 PM
masseysbronco
1978 - 1996 Big Bronco
Jul 26, 2005 02:22 PM
wardenj
Aug 11, 2002 11:10 PM
