hood support spring
Old Jun 26, 2020 | 02:52 PM
ulmapache's Avatar
ulmapache
hood support spring
Ok...where can I obtain the tool to wind the hood support spring...1984 f250... Or do I have to have one fabricated...
Old Jun 26, 2020 | 03:01 PM
FuzzFace2's Avatar
FuzzFace2
How did you take it off and why
I don't think there is a tool as you don't take the springs off them for any reason.
Best bet is to get another set with the springs still on them.
Dave ----
Old Jun 26, 2020 | 04:12 PM
ulmapache's Avatar
ulmapache
Dave ----
Replaced hood with one that wasn't bent..springs are still on them, just need tool to wind them so they work...saw something similar that worked on Chevy springs...guy made it out of a compression fitting with a slot cut into it. Looked on the tube for a video on how it is done...no joy...Guy with Bronco has the same problem...
Old Jun 26, 2020 | 08:20 PM
FuzzFace2's Avatar
FuzzFace2
Sorry I cant help as I have never dealt with springs that were off the hinge.
I will have to look over mine to see if there is a way to get them back on that is safe.
The other thing is to get another set from the junk yard.
Dave ----
Old Jun 30, 2020 | 10:25 AM
ulmapache's Avatar
ulmapache
Dave ----
Will have the same problem... It all starts when the hood lift assists are detached from the hood...
Old Jun 30, 2020 | 12:13 PM
FuzzFace2's Avatar
FuzzFace2
I CALL THAT BS!
I took my hood off my 81 F100 and was off for 4 years almost to the month.
My parts truck had the hood off, PO pulled and sold the motor, hood was in the bed but springs still bolted to the fenders.
When I needed to install a set of springs I picked the best of the 2 sets I had, cant remember what set I used but both were just the same.
I bolted them to the fenders just like the factory did then bolted them to the hood and they keep the hood up.
They did not unwind so I don't know what you got going on but if you find a set in the junk yard open the hood and hold it up.
Unbolt the springs from the hood (2 bolts IIRC) and them undo the (1? bolt) on the fender and pull the assy. out.
Nothing to it.
Some pictures of my hood open and nothing but the spring holding it up.
So I don't know what you are doing but it's not the right way to do it. I also would not even try to "re-spring" that spring to make it tighter just get JY ones.
Dave ----
Old Jun 30, 2020 | 01:46 PM
kramttocs's Avatar
kramttocs
The springs have stop ears/tabs on them that prevent what would otherwise be a dangerous situation. I agree with Dave - find a good pair and toss the ones you have. A lot of things could go wrong using a homemade tool to try and wind these. Is it worth it?
Old Jun 30, 2020 | 02:01 PM
ulmapache's Avatar
ulmapache
Ja...after reading this and another thread on the subject, I think they may be just worn out...will buy a new pair...
Old Jun 30, 2020 | 02:29 PM
ulmapache's Avatar
ulmapache
Reply to FuzzFace BS comment.... yes, the springs can and do fall off...
Old Jun 30, 2020 | 06:09 PM
FuzzFace2's Avatar
FuzzFace2
I have never seen one come apart with out someone forcing it.
Either to make it weaker or in your case make it stronger is taking your life in your hands and I would not try it.
There is a lot of energy stored in it that can hurt you when it gets away from you.
Dave ----
Old Jul 1, 2020 | 12:21 PM
Franklin2's Avatar
Franklin2
Looks like to me in the picture below, one of the stops is severely bent probably letting the arm go places it shouldn't go.
Old Jul 1, 2020 | 03:05 PM
FuzzFace2's Avatar
FuzzFace2
Good catch I bet because the hood was folding in half someone bent the stop out of the way so the spring could "unwind" some so they could remove the springs to save the hood?
I have never seen springs just falling off with out some lift & death help
The GM type normal looking hood springs are just a bad but if you could expand them so there is space between the coils you can put things between the coils and release the spring and it will stay expanded.
And don't get me started on trunk deck lid rod springs !!!!! You have to be in the trunk with them when trying to set them and no where to run.
Dave ----
Old Jul 14, 2020 | 02:42 PM
ulmapache's Avatar
ulmapache
So..problem solved...just installed new support assist assembly...hood works fine now..44 bucks the pair at Rock Auto. Oh, a note...the hole where they attach to the inner fender is a bit small...might have to drill it out so it will fit the collar on the bolt where it rotates...not much...just a very little...
Fleetwood271
Jun 22, 2020 09:50 AM
52'F-3
17
Sep 19, 2012 03:28 PM
imlowr2
Apr 29, 2007 01:10 PM
bbearls
Feb 8, 2005 08:49 AM
53TOY
Jun 9, 2003 11:44 AM
