FTN's T4/SXE Build/Conversion Thread
#601
#602
I’m not sure if I should proud or ashamed of that.
The next data-logging session will still be with the 35psi boost limit so we can make a meaningful comparison between the performance of the 6.0 CAC and the Tapercore. We’ll see how brave I am after that and may up the boost limit during the same excursion.
#603
#604
#605
#607
I upped the boost limit. Other factors are at play now with regard to maximum boost reached.
EDIT: It looks like I messed up setting the higher limit. I will have to redo the second round of runs.
#608
#609
#610
Hard to say when ambient temperatures are some 50+ degrees lower than when I logged with the 6.0 intercooler. Let’s put it thia way, MAT is lower than IAT with the Tapercore when cruising. That was not the case with the 6.0 intercooler.
#611
what are your egt's at max boost set and rpm's at 3500 ? I can't really see gauge , but it looks like past 1200. I'm just curious as a comparison to what I'm getting. Do you feel you experience turbo lag a little when hammering the pedal? What is your max APP when hammering it ? I'll give you my data I got so far as a comparison. I'm not sure how to do all that fancy video stuff, but perhaps someone going to the N.GA. Meetup can help me post a few runs. I know for sure my egt and boost are way lower that what i expected on my setup. I've been recording some runs lately and I'm still trying to figure out the data enough to be useful to others.
#613
#614
EDIT: Oops, just realized I failed to answer your first question. In the Economy tune, EGT tops out at 1,200. In the Performance tune, it just keeps climbing the longer I keep my foot in it. I think it's because of the controller limited boost. I am slowly working my way up to the point where boost is limited by fueling and not the VGT/VNT controller.
*blush* You're welcome. There's another acronym for your parody video: IDGB!!!
#615
The 6.0 CAC isn’t much of an upgrade. I’ve put these in a couple of trucks and found no noticeable/measurable change.
