Rear end gear change
Hey guys. My rear axle code is 14J. Which I know means it has a 9" rear end with 3:1 ratio and front power steering. What I don't know is how many splines is in the yoke. This is my project and I want to put 3:70 or close to that in the rear end. Do you guys have any good advice on swapping to a limited slip diff around that area of ratio and what brands are good? I'm wanting it to be a clutch LSD because I'm terrible at wiring (e-locker) and I would have no idea what I'm doing with air pressure (air locker). This will be my first real upgrade since I bought the truck and any info on ease of installation or part #s or anything would help.
If you're talking about the pinion shaft splines, I'm pretty sure all 9" Fords are the same. If you're talking about the axle splines, you have 31 spline axles.
WDM-CF = Ford 9" non-locking w/ 3.00 ratio, uses the #88 service parts list. From the tag you have a '79 (9ED) 9=year, E=May, D=4th week. In '79 Ford used two different size bolts to retain the brake backing plates to the axle housing, either 3/8" or 1/2" bolts were used. The WDM-CF used either so you would need to visually check to see which ones you have.
According to the parts list the 3/8" equipped housing used axle P/N D8TZ-4234-D and the ones with 1/2" bolts used axle P/N D6TZ-4234-A both axles are 31 spline.
Ford did offer a 3.70 ratio ring and pinion (P/N B7A-4209-M) but I like Yukon gears myself.
bfensler
11-11-2004 05:07 AM
dead_eye
07-05-2003 12:54 AM
Crazy Canuck
05-18-2003 12:48 PM
