rear gear change
Old May 6, 2005 | 05:41 PM
jethro bodine's Avatar
jethro bodine
rear gear change
I currently have a 3.00 rear gear in my F100, I have a 9'' 28 spline, I'm running a 390 3 speed, I was thinking of changing my rear center section to a "posi unit" I have a donor 9'' but I'm not sure if I can swap these out. the tag on the donor says the following. WFY-A5 6BC
2L75 9 480E
can someone let me know if this will work. also if its a 2.75 gear ratio I want to change to a 3.73 I did pull the axle and it does have 28 splines. thanks for any advise..
Old May 6, 2005 | 06:04 PM
banjopicker66's Avatar
banjopicker66
As long as the punkin (3rd member, chunk, etc) has the same number of splines as your axles, you can interchange easily.
I know one fellow in California who uses a low geared (high ratio) rear end for stump pulling during the year, but when goes on a cross country vacation, he puts in a high geared (low ratio) rear end for better mileage on the freeway.
Old May 6, 2005 | 07:30 PM
barry's Avatar
barry
That axle was used in a 72 Ford car originally. It's a 2.75 posi rear. It is also 28 spline.
Barry
Old May 6, 2005 | 11:41 PM
cdherman's Avatar
cdherman
That would be a decent "posi" or properly termed "limited slip" rear. But 2.75 behind a 390?
Rebuilding a 9" rear usually costs more than just finding the correct ratio to start with.
Your original post indicates you would rather have a 3.73 or so. You are better off with that ratio. If the chunk/pumpkin/3rd member you currently have is the wrong ratio, sell it and find one that is right.
Old May 7, 2005 | 09:21 AM
jethro bodine
thanks for your help. I think I will change the gear ration in the posi to a 3.50 or 3.73
I have 3 speeed with 28'' tires
Old May 8, 2005 | 06:29 AM
jowilker's Avatar
jowilker
jb, The 390 will pull the 2.75 gears, and as long as the truck is empty will do pretty good. The 3.50 or 3.75 ratio will give you more snap, make tire roasting a breeze, but you are gonna buy a lot more gas because the engine will be turning more rpms than it is now, and tire wear will likely fly out of the window too.
But it's only money, right??
John
Old May 8, 2005 | 08:16 AM
cdherman's Avatar
cdherman
The little 28" tires do make a difference. With those, I would agree that the 3.73 is a tad high.
