zinc additive needed?
Old Jun 22, 2020 | 03:04 AM
fixorepairdaily's Avatar
fixorepairdaily
94 ford f250 351w. Did these engines come with a roller or flat tappet cam? Do i need a zinc additive with my oil? Exhaust has no cats.
Old Jun 22, 2020 | 10:01 AM
jackietreehorn's Avatar
jackietreehorn
Mixed bag in 94. Good chance you have either. Zinc won't hurt for sure.
Old Jun 22, 2020 | 10:03 AM
TobyB's Avatar
TobyB
By 94, you should be rollin'.
To confirm, look for a F4TE casting number on your block...
t
Old Jun 25, 2020 | 02:25 PM
fixorepairdaily
Thanks yall. I have the F4TE block. Does this automatically mean i have a roller cam? If that doesnt confirm it is there a way to confirm without pulling apart the motor
Old Jun 27, 2020 | 09:01 PM
jackietreehorn
Yank the dizzy and determine if the gear is cast iron or steel. Only roller cams got steel gears.
Old Jun 27, 2020 | 09:06 PM
timbersteel's Avatar
timbersteel
You can also pull the valve cover. Loosen the rocker, and measure pushrod. Roller cams had longer pushrod. Someone can tell you the length. I dont have the number off hand.
Old Jun 28, 2020 | 08:55 AM
jackietreehorn
Also if you are adventurous, you could probably stick a borescope camera into the intake valley through the distributor hole then through the oil return hole or maybe IAT sensor port or the like and look for the lifters retaining "spider". That would be a dead-giveaway for a true roller.
Old Jun 28, 2020 | 10:21 AM
Conanski's Avatar
Conanski
You mean shorter pushrods. Roller lifters are longer so...
And you don't even have to measure it, just shine a light down the pushrod hole and look for the dogbone around the lifter, if they are present it's a roller motor.
Old Jun 28, 2020 | 05:38 PM
timbersteel
Thanks for catching that Conaski.
I have both flat tappet and roller cam engines. I missed that when I replied.
Old Jun 29, 2020 | 07:28 AM
GNR22's Avatar
GNR22
Has anyone seen a '94 with an F4TE block with a flat tappet cam that wasn't a Lightning?
I've seen a bunch of '94's with flat tappet blocks and flat tappet cams, but never one that was mixed (not including Lightnings obviously).
beartracks
Jan 28, 2017 07:06 PM
1990-f250
Jun 11, 2013 10:35 PM
BRay09
Jul 4, 2009 12:33 PM
bigblocksix
Nov 29, 2006 03:45 PM
Brian460
Jul 12, 2003 12:58 AM
