roller 351w
Old Nov 25, 2006 | 03:06 AM
bigblocksix's Avatar
bigblocksix
roller 351w
anyone know what year the 351w went to a roller cam in the trucks, or if it did? thanks
Old Nov 25, 2006 | 06:15 AM
jade79's Avatar
jade79
I think 94 and later blocks had provisions (bolt holes in the lifter valley for the spider etc.) for a roller cam even though a lot still ran flat tappet cams. The block should have a casting number of F4TE.
Old Nov 29, 2006 | 02:27 PM
bluepartsman's Avatar
bluepartsman
I had a 94 351W with a roller cam.
Does anyone know when or if the 351W came stock with roller tip rockers. Can I put a set of 1.7 ratio rockers on my 85 351W with a toque cam?
Old Nov 29, 2006 | 02:58 PM
Conanski's Avatar
Conanski
Originally Posted by bluepartsman
Does anyone know when or if the 351W came stock with roller tip rockers. ?
Never did in the regular F Series, maybe with the G1 Lightnings, not sure.
Yes as long as the total lift doesn't exceed 0.500"... maybe even 0.480" to be safe. Valve spring coil bind is the immediate issue, but piston to valve contact is also an issue depending upon cam duration.
Old Nov 29, 2006 | 03:45 PM
bluepartsman
Actually the 94 truck with the roller cam was not stock I forgot the guy put it in before I bought it.
The cam I have is a Clevite MC 1775 RV cam with valve lift 448 int/472 exh and duration adv. 270 int/280 exh. So I guess I should stick with the stock 1.6 ratio rockers, so i don't have to worry about clearances with the 1.7's. But I will be getting some roller rockers. Don't know how much they will do for me but I can get a whole set for $100
robjs111
Apr 23, 2009 08:55 PM
Tim Young
1966 - 1977 Early Broncos
Oct 13, 2008 12:07 AM
Shernius
Mar 3, 2005 08:26 AM
Shernius
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 11, 2004 09:12 PM
Spdalit
Dec 14, 2002 10:30 AM
