I'm starting to lean tword a carb setup more any good threads on here goikg over the conversion? I'd rather not tear into that motor again
yes, sir, and if your trans is electronically controlled by PCM, its one more thing to figure out. copy and paste, in google, see below
92 f150 5.0l efi to carb:ford-trucks.com
Maybe SPE will chime in here. Could the PimpX computer be setup to run that cam?
If so, it might be the easiest solution... though it may be a bit beside the point if that cam isn't well suited to truck use.
After going through MAF conversion for a "performance engine" my self, Had I to do it again, I'd lean the slightest bit toward carb. Unless you are racing or building a show car, EFI is a lot more work and effort than I care to put in, especially considering tuning. It still bothers me to put a carb on something that never came with it; all the trouble and drive-ability issues of a classic carb with the aero-dynamic looks of the 90's.
The exception here would be directly swapping MAF from say a 95 truck to say a 95 F-250, as opposed to what I did, trying to make a 95 mustang harness fit a 88 truck.
I believe they are no longer here. Saw a post a few weeks ago where they stated the vendor fees were pricey and their business was down. No payment resulted. Then I believe they tried to come back as an individual which triggered the admins booting them off.
There are no cam restrictions, run as big of a cam as you want.
Also, just to be clear, I was TOLD to create a new account (by the company that runs the forum) if I wanted access to the forum after ending the vendor program. Didn't break any rules in creating a new account and only did it because I couldn't even view the forum with the old account. Sales aren't down, just the sales generated from the activity on here didn't offset the costs associated with being a vendor.
I have a 92 Flareside that i swap the 302 flat tap with a 351w roller. I pick up the Fiveology harness and pick up a HOG0 Ecu. it seems pretty straight forward when re pining but i got stuck when you re pin the old pins to the new pins on old pin 49 HEGO G (ORG) for the new pin it says (GND) ground am stuck if its a ecu ground or ground it to the body.
