Ford Racing MAF Conversion Kit
Old Oct 25, 2005 | 09:36 PM
TheRoadVirus's Avatar
TheRoadVirus
I'd like to do this conversion on my 1990 F-150 with a 302 and speed density. The part number for it is 'FMS-M-9000-T50' at summit if you care to look it up.
But I had a couple questions. It says it includes the ECM (EEC-IV), Mass air flow sensor, wiring harness, hoses, clamps and brackets. But do I need anything else? It lists injectors as one of the things with a yes/no answer and it says it doesn't include them.. but does that mean it needs them? I just need to know so I can do it all at once.
Also; a few people were saying because the mustang gt computer was put in some wiring changes had to be made? I'm just confused because I have the original truck computer and apparently that's whats put in from a stang.. so would it run fine with them just switched no wiring changes? because I really don't think the wiring was changed. And If it was is that going to screw this swap up? How can I tell..
Thanks in advance guys.
Old Oct 25, 2005 | 09:55 PM
EPNCSU2006's Avatar
EPNCSU2006
The kit takes care of all the wiring changes that need to be made with a simple plug in harness. The stock injectors on your truck work fine with the conversion kit. The kit comes with an '89-'93 mustang 5.0 computer. If you are unsure of the wiring of your truck, I would start testing wires and pin locations before installing the kit. If the wires are already changed, you'll need to swap them back to the truck pin locations for the kit's overlay harness to work.
Old Oct 25, 2005 | 10:07 PM
TheRoadVirus
Do you have any idea if it's possible to run the Mustang computer without the wiring changes? I'd be suprised if it was messed with..
Old Oct 25, 2005 | 10:09 PM
Blurry94's Avatar
Blurry94
What is the calibration code on the PCM you are currently using?
Old Oct 26, 2005 | 04:09 AM
EPNCSU2006's Avatar
EPNCSU2006
For the most part the wiring functions are the same, but a few are different. The main difference is the fuel injector wiring - the mustang has 8 wires and the truck only uses two control wires. If a mustang computer was just connected to the truck harness, it shouldn't work, but I've never tried so I don't know exactly what it would do.
Old Oct 26, 2005 | 05:42 AM
TheRoadVirus
One more thing.. should I expect any power losses with this change over?
Old Oct 26, 2005 | 06:53 PM
EPNCSU2006's Avatar
EPNCSU2006
If anything, you should experience a slight gain.
Old Oct 27, 2005 | 12:34 AM
LxMan1's Avatar
LxMan1
The truck conversion uses a later model batch fired injectors truck ECM.
Old Oct 27, 2005 | 06:14 AM
EPNCSU2006's Avatar
EPNCSU2006
The Ford Racing MAF conversion for F150 trucks uses an '89-'93 5.0 mustang computer that sequentially fires the injectors.
Old Oct 27, 2005 | 06:17 AM
TheRoadVirus
If I'm not mistaken this kit should be plug and play, no?
Old Oct 27, 2005 | 09:27 AM
Blurry94's Avatar
Blurry94
It would be impossible to just plug and play an SEFI PCM into a batch fired system because of the way the injectors are wired.
Old Oct 27, 2005 | 09:40 AM
EPNCSU2006's Avatar
EPNCSU2006
I know that and I said that earlier (see reply #5)! The kit is plug and play because it takes care of the wiring with the overlay harness included in the kit.
Old Oct 27, 2005 | 10:28 AM
Huntsman's Avatar
Huntsman
I just received this in an email yesterday from another web site, it looked interesting.
http://www.fordmuscle.com/archives/2...sion/index.php
Old Oct 27, 2005 | 02:41 PM
Blurry94's Avatar
Blurry94
I guess I did miss that.
Old Oct 27, 2005 | 04:12 PM
TheRoadVirus
[QUOTE=Huntsman]I just received this in an email yesterday from another web site, it looked interesting.
http://www.fordmuscle.com/archives/2005/10/MassAirConversion/index.php[/QUOTE]
I read through this just now and they do mention the kit I'm looking at, but they don't use it. I went through the installation and they have to do a fair bit of wiring changes..
Just double checking, but the overlay harness included in the Ford Racing kit should eliminate the need to screw with the wiring, no?
One other thing I noticed is in the picture of the Ford Racing kit it looks like there's only 6 injector connections rather than 8.. hrm..
