Code PO455 (gross leak)
Old Jun 17, 2020 | 02:17 PM
Dantucker1's Avatar
Dantucker1
4wd Low
2008 F150 5.4 Anniversary Edition. I am working to solve a code P0455 code that has been set on the truck. So far I have replaced the evaporative emission return tube, it was beginning to break down giving off a powdery substance. It did not solve the problem. I have replaced the vent valve and waiting for it to complete the cycle! My next step, should it not fix the problem, is to run a smoke test, I found out that my Son has a smoke machine I can use. My question is where do I introduce the smoke into the system? Thanks for your help!
Old Jun 17, 2020 | 10:28 PM
Lime1GT's Avatar
Lime1GT
Brake booster hose should work. I assume you checked the gas cap?
Old Jun 18, 2020 | 08:00 AM
Dantucker1's Avatar
Dantucker1
4wd Low
Yes, I replaced the gas cap! I hope I have it taken care of but want to be ready if the code returns. Thanks for the reply!
Old Jun 18, 2020 | 10:38 AM
alloro's Avatar
alloro
That or the gas tank fill tube.
Old Jun 20, 2020 | 11:58 AM
Dantucker1's Avatar
Dantucker1
4wd Low
I found the source of the problem without having to use the smoke! After filling the fuel tank up I noticed a fuel leak, I had not noticed a leak previously. Following the leak pattern I could tell it was coming from the fuel pump area and with the use of a mirror could see that the vent line fitting had a hole in it. Looked like a rodent had chewed it! Thanks for the replies.
Old Jun 23, 2020 | 11:30 AM
alloro's Avatar
alloro
That's odd, usually they chew wires not hoses.
Old Jun 23, 2020 | 12:52 PM
Dantucker1's Avatar
Dantucker1
4wd Low
It wasn't the hose it was the fitting which was chewed, I have seen them chew rubber but not hard plastic except marine grade rubber coated nylon! You would not think they would bother with an every day driver.
Old Jun 26, 2020 | 10:12 AM
alloro's Avatar
alloro
That's worse because you have to change an expensive part instead of a low cost piece of hose. If they're going to chew, they should be more considerate in what they chose to chew.
Old Jun 27, 2020 | 08:19 AM
Dantucker1's Avatar
Dantucker1
4wd Low
Well it could have been worse, at least I didn't have to drop the tank or remove the bed!
steve2003
1997 - 2003 F150
May 28, 2020 08:35 AM
Boltz1963
1997 - 2003 F150
19
May 9, 2019 07:13 PM
Schneiderboy07
6.4L Power Stroke Diesel
Feb 17, 2012 04:35 PM
4inchlovin
13
Oct 14, 2010 01:04 PM
lariat97
1997 - 2003 F150
Sep 9, 2005 10:28 PM
