Setting Up A 9"
Old Jun 14, 2020 | 01:28 PM
blake in spokane's Avatar
blake in spokane
Setting Up A 9"
Gotta Ranchero 9" Do I weld the leaf spring pads on straight/90' and shim pinion angle? Or weld on with pinion angle? Plus if I narrow the axle, do I center the pinion to the frame? Or offset with 2 equal length axles?
Old Jun 14, 2020 | 02:36 PM
Flitebynite's Avatar
Flitebynite
This is a link that was shared with me here by another member.
Made it very clear how to proceed.
https://www.hotrodhotline.com/md/htm..._harmonics.php
Chris
Old Jun 14, 2020 | 02:38 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Don't weld on perches until you establish final ride height then go on pinion angle. Unless you offset the pinion approx four inches the axles won't be the same length. Factory for most trucks is 2"offset but you center it in the truck if you like(2 wheel drive only), I centered mine.
Old Jun 15, 2020 | 09:51 PM
AZAV8's Avatar
AZAV8
Remember, that any welding on the housing will distort the housing and it WILL have to be straightened after all welding is complete. The shop where I had my brand new John's 9 Inch housing installed had to straighten the housing after they welded on the spring pads and the torque arm.
desi778
Oct 5, 2012 09:49 PM
glosol
15
May 22, 2011 06:33 PM
minutofgroundhog
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 11, 2007 12:07 AM
Sixoh
Apr 5, 2004 09:03 PM
terekpau
Jul 23, 2003 07:50 AM
