Fuel lines
Old Jun 10, 2020 | 07:37 PM
OBS-Addiction97's Avatar
OBS-Addiction97
Fuel lines
Hey all,
I'm wondering what fuel lines are best to use for a custom setup.
my last setup I had the blue Parker house and it seems to dry rot / crack relatively quick. I have a sump to an A1000 ran in 5/8 and 1/2” to the heads.
I was maybe thinking of using steel braided hose or hard lines.
thanks in advance.
Old Jun 10, 2020 | 08:26 PM
RacinJasonWV's Avatar
RacinJasonWV
Riffraff has this for the engine fuel lines. But I’m wondering if you’re asking about total system...
https://www.riffraffdiesel.com/fuel-...it-7-3l-99-03/
Old Jun 10, 2020 | 09:36 PM
OBS-Addiction97
sorry, should have been more specific.
I have a competition irate system.
i want to use a better quality fuel line than the blue hoses that come with the kit. All in the frame rail.
Old Jun 11, 2020 | 05:54 AM
FordTruckNoob's Avatar
FordTruckNoob
I built all my flex lines out of this stuff:
https://aeroquipperformance.com/look...12&category=48
Old Jun 11, 2020 | 10:55 AM
OBS-Addiction97
which hose did you use? Their website is a bit glitchy on phone.
how is the hose holding up?
thanks.
Old Jun 11, 2020 | 10:59 AM
FordTruckNoob
For fuel, I used -6 on the supply side and -4 on the return. Brake lines to calipers are -3. Brake line from the frame to the rear axle T is -4. They are holding up very well. Be warned though, the metal braid on the hose will make anything that touches them wear quickly. Be sure to put protective sleeve over any potential points of contact.
Old Jun 11, 2020 | 04:20 PM
timmyboy76's Avatar
timmyboy76
I hit up the local hydraulic shop and had braid lines made...using AN fittings off fuelbowl and heads...
michbol
Sep 15, 2013 01:13 PM
lnthecurly
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Aug 6, 2011 02:46 PM
RA31925
Jun 22, 2011 01:01 PM
natew
Oct 2, 2010 05:51 PM
salewit
Dec 9, 2005 06:17 AM
