Crank no start no injector clatter
  #46
Old 06-13-2020, 07:07 PM
bismic's Avatar
bismic
bismic is online now
Received 2,527 Likes on 1,757 Posts
The biggest issue in the list of codes is B1318 - at least IMO.
Battery Voltage Low in the VSM, Battery Voltage Low in the 4x4 Module, Battery Voltage Low in the HEC (Instrument Cluster), Battery Voltage Low in the RCM, Battery Voltage Low -in the GEM-Control Time.
Also, B1483: Brake pedal input circuit failure
  #47
Old 06-13-2020, 07:33 PM
bismic's Avatar
bismic
Either some of those are old codes or you still have a voltage issue going on.
  #48
Old 06-13-2020, 07:58 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
Batteries are 100% charged and load tested. I can't see there's being a voltage issue.
I don't seem to know what is going on between all the codes, would they trigger a no start? Also no buzz on the buzz test? I don't quite understand at all what or where I should be looking
  #49
Old 06-13-2020, 08:09 PM
bismic's Avatar
bismic
A voltage issue isn't always the batteries ...... You may have a wiring issue or a ground issue. Assuming the codes are not "hold-overs", they point at a voltage issue.
  #50
Old 06-13-2020, 08:10 PM
bismic's Avatar
bismic
IMO you need to ignore the no-buzz for now. Focus on getting the things that we KNOW are needed for a start (like cam/crank sync) - that follows Ford's advice in the FICM Guide (troubleshoot no-sync issues first).
  #51
Old 06-13-2020, 09:03 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
I gotcha, gonna work on that tomorrow! thanks again sir! you are ever so kind! you are an angle!
  #52
Old 06-13-2020, 09:21 PM
bismic's Avatar
bismic
One thing easy to do with ForScan is to do an injector test with it. It will activate a spool valve coil on each injector in sequence - you can hear it click.
  #53
Old 06-13-2020, 09:26 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
i did not get any click from any injector when doing the test
  #54
Old 06-14-2020, 07:34 AM
bismic's Avatar
bismic
This would be my approach:
Get the cam sensor work done.
Restore the cam/crank sync
Make 100% sure the FICM connectors are solidly plugged in (the connectors should "click" when latched in)
Check all ground wires (if you haven't already)
Clear codes
Try starting again
Pull codes if it doesn't start
Do you still have a FICM that gave you the "weak injector clicking"?
  #55
Old 06-14-2020, 05:42 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
we have good news and bad.
I restored cam/crank sync the replacement was a success!
with the original ficm plugged in i cleared codes and got nothing besides p0113... no clatter, same scenario.
all good voltages aswell.
I plugged in the replacment FICM and got a u0306! not programed? im pretty confused.
I cleared codes and switched it back to the original ficm and got the same p0113 no clatter same scenario.
both ficms have good volages an sync.
  #56
Old 06-14-2020, 05:50 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
to clear things up all 3 ficms i tried became "weak". the first replacment worked fine for a week and when i started to give me problems the guy i got it from was willing to swap it out for another. the second replacement worked only for a few days then got the rough starts and grew weaker with every start then after. my original got weak and all of a sudden worked good got weak was dead completely then magically worked after a weak of sitting. it fired up and drove fine the day i replaced it with the first replacement... now nothing... im beginning to think its the PCM
  #57
Old 06-14-2020, 07:07 PM
bismic's Avatar
bismic
Good that cam/crank sync has been resolved.
So, please post the three FICM voltages with KOEO, and when cranking
FICM MPower
FICMLPower
FICMVPower
Also, have these FICMs been OEM units or aftermarket?
  #58
Old 06-14-2020, 07:09 PM
bismic's Avatar
bismic
Oh, regarding the software compatibility (U0306 code), I have seen that before and have not known it to cause any issues.
  #59
Old 06-14-2020, 07:28 PM
bismic's Avatar
bismic
From what you have said, a new FICM enables you to run for a short time - each time a new one is installed.
That says to me that something is killing the FICMs.
For those more wise than I on electrical systems - could an alternator diode issue cause A/C voltage leakage (or some such strange problem that could kill FCMs but not be detected by DC voltage measurement)?
I know that poor grounds can cause surges that can cause issues, but it seems that has been ruled out. Not sure if the alternator has ever been tested though (remember the recommendation 3-4 days ago?).
  #60
Old 06-14-2020, 08:20 PM
OUTATIME's Avatar
OUTATIME
OUTATIME is offline
All units are oem remans both from 2013
KOEO
MP-49v
LP 12.5v
VP- 12.0v
While Cranking
MP- 49v
LP -drops to 9.5v
VP drops to 10
vref 5.0
Quick Reply: Crank no start no injector clatter
