Crank no start no injector clatter
#61
what is the process for testing the alternator without removing it?
Talked to the guy i returned the ficm to and he says that he plugged in that ficm i returned into another truck and it ran fine which makes me think its my PCM but thats just my guess. its not the original PCM in the truck either i had to replace a couple years ago when i had a no crank issue. took weeks to check the electrical system to find out it was the PCM... man that was a rough time! kinda coming to the same conclusions unless there is something im not checking.
#62
Yeah Mark, with diode issues you can see normal to elevated DC voltages. If you put a voltmeter across the battery terminal or alternator output and frame, turn the meter to read AC, you can see how much AC is present. It will change with the load as well.
A couple of graphs I'm using in a vid. Most alternators can have a 0.25v AC ripple, some up to 0.5v. But others 0.5v can be normal and 1.0v for bad. It's best to view on an scope rather than a meter. What that doesn't seem like much, the frequency is what can get some things and the DC voltage might be up over 15v. Good electronics will have a design so this does not affect its circuits, but .........
#63
#64
#65
#66
#69
#70
#71
Your batteries are not okay. Maybe you put some dead/weak batteries in your truck?. The low volts at startup will fry your FICM. Also check the wiring and the connections on batteries and frame. Use jumper cables (only for testing) and connect the batteries and (just to see if the volts go up) install additional cables in addition to the existing battery wiring.
Use a FICM from a truck that is running and watch out for the better volts.
#73
