Speedo problems
Old Jun 8, 2020 | 09:59 PM
Motate455's Avatar
Motate455
Speedo problems
So my Speedo on the 77 f250 4speed is wonky. Barely registers.
so I replaced the cable and hooked it to the Speedo and ran a drill and it worked fine.
gear on other end of the cable looks good but when I put it in and drive it is bad but working up to around 15 mph and then is bad
do you think it’s the gear inside the transmission? Dennis-carpenter has all the gears, figured I might just replace both so they fresh.
Can you replace the trans gear easily?
Old Jun 9, 2020 | 02:03 AM
Ozzie H.'s Avatar
Ozzie H.
The driven gear is much easier to replace than the drive gear. Also it is more likely the problem. Changing the drive gear requires partial disassembly of the transmission. Changing both would be good, but would require some work.
OGB
Apr 2, 2020 12:44 PM
agaristo77
1978 - 1996 Big Bronco
May 3, 2012 08:04 AM
mlcopen69
Oct 28, 2008 10:04 PM
Chuck88
Aug 18, 2006 04:29 PM
Ray D
Aug 22, 2000 12:10 PM
