Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
shaking and acceleration
Old Jun 8, 2020 | 10:03 AM
rugrat100's Avatar
rugrat100
we have a 2012 ford escape. it has 104,000 miles.on occasion for no reason the car while driving at about 40 mph starts to shake and lose acceleration. we have replaced the motor mountsreplaced had all the tires balanced and rotated , full wheel alignment, and had a full tuneup. tires and brakes are in good condition. has anyone had this issue.
Old Jun 8, 2020 | 11:37 AM
clintbonnie's Avatar
clintbonnie
My first thoughts would be your torque converter maybe going bad.. got this off the internet:
Torque Converter Failure Symptoms
  1. Slow speed juddering
  2. Vibration/droning noise when under load between 2,000 and 2,500 rpm (see above post). NB. ...
  3. Jerky 1st to 2nd gear change (this was helped by the gearbox oil flush incidentally)
This could cause your transmission to go next.. (a friend's 2014 Escape's torque converter went bad at 80K and it ruined the trans.. $6000 later, the car is back on the road. )
Old Jun 8, 2020 | 11:56 AM
rugrat100's Avatar
rugrat100
thanks for the input
Old Jun 8, 2020 | 06:24 PM
clintbonnie
What engine does your Escape have ? Be sure to let us all know what the problem was when you solve it...
Old Jun 9, 2020 | 08:38 AM
rugrat100's Avatar
rugrat100
4 cylinder. will do its at dealer now
Old Jun 27, 2020 | 03:53 PM
clintbonnie
Did you figure out what your problem was causing your shaking, etc ?
Old Jun 28, 2020 | 04:46 AM
Yahiko's Avatar
Yahiko
Some things to keep in mind when going to the dealership for service.
  1. It going to cost more than you think it should.
  2. They likely will have it for a while,
  3. They may not get the issue fixed the first time.
  4. It's going to cost way more that it really should. You were right on that in line #1.
gregstith
18
Jul 10, 2019 11:54 PM
04mountaineerguy
Apr 3, 2009 02:55 PM
glipscomb
Apr 27, 2006 07:57 PM
azerndt
Aug 31, 2004 02:15 PM
Belle
May 14, 2003 04:28 AM
