Khan's 95 Build thread
#331
I can't wait till I get the new wheels and tires Kahn convinced me to get installed
#332
The following users liked this post:
#334
#335
#336
#337
Hey Khan, getting ready to order some paint and I was wondering if you could tell me what your paint code/ color is for your truck? I like it and might see if they can use the paint code to mix up a batch. Looks like there were a few different whites they painted with. Also, curious if you have to JB weld a boss on the fuel tanks and run a line between the two or did just putting the one on the filler neck work for the fuel filler trick? Sorry for all the questions.
#338
The tank mod I JB welded 3/4" hose barbs on both the fill neck and the tank. They work awesome and it's definitely worth while since your truck is stripped down.
No worries on the questions.
#340
#341
While under the influence I ordered CNC Fabrications Stage 1 Valve springs and Manton .120 thick 3/8's push rods. Thanks @Hit Man X for constantly putting it in my head! now to get/borrow tools for measuring valve spec to shim these out to 1.800 @ 119 lbs. I'm debating shimming out to 1.790 or so to get about 124 lbs. on the springs. anyone more knowledgeable on valve springs?
#342
#343
The following 3 users liked this post by 427 fordman:
#345
