'78 D60 Swap
Old Jun 9, 2020 | 12:59 AM
CumminsCrew74's Avatar
CumminsCrew74
Originally Posted by moose4x4
The inner axle seal area should be ok. As long as the ring of the housing around the outside of the seal goes. If it is flat all the way around, It should be OK. It looks to have a couple of chips out of it, But that was probably from the machining operation at the Spicer plant. As long as the bearing race fits and does not rock around, should be good. Of course you need new seals, The diff shims go under the bearing cone, no under the race.
The heated mirrors, I know ford used them on a L9000 because one of the fire tankers we built had them from ford, The one on passenger side also had a rotation feature.
I appreciate the input. I went by the local machine shop and the guy said the same thing. RVT black should solve the issue when i put in the new seals and there shouldnt be an issue. He said if i was really worried he could weld it and machine it for $150 bucks or so. i think ill just go the RVT route, even though if i were to get it machined, now would be the time to do it since its not on the truck and is in pieces... and "relatively easy" to move around.
Old Jun 9, 2020 | 01:09 AM
CumminsCrew74
Originally Posted by scott79
WOW! That D60 has been rode hard. Most of those parts can still be purchased thru Spicer but not all of them. I have had good luck buying good used parts for them over at Pirate 4x4 forum. If you aren't a member there, you definitely should join, lots of good dudes there!
https://www.pirate4x4.com/forums/
While you are at it, replace those junk warn lockouts with the original OEM factory Spicer lockouts!! Spicer is the best!! just my $.02
Yeah it definitely was used!! thanks for the input on hubs. might upgrade to 35 spline outers and will have to get hubs accordingly. The guy i purchased the axle from is giving me a new warn hub. Might sell and put toward build. Ah man! As an Oregonian i almost feel obligated to support Warn!
Old Jun 9, 2020 | 01:15 AM
CumminsCrew74
Originally Posted by maddogjohnson
Awesome detailed pictures. I appreciate seeing them.
Of course. I will do my best to keep the picture trend going. of course its somewhat of a hassle. Still wish i would've taken more photos when i did the Cummins swap..
Old Jun 9, 2020 | 01:31 AM
CumminsCrew74
So i had a discussion with the gentleman that sold me the 60. He had no clue of the crack and i believe him. He bought and never ran it. Genuine guy and he wanted to keep in touch, so i knew he wasnt trying to get over on me. Anyway, he has an extra set of outer knuckles hes going to give me, along with new tie rod and drag link to convert to cross over steering, which i planned to do. He is also giving me a set of outer axles that are supposedly undamaged. Might use them or sell and budget or 35 spline outers. I know, probably dont need them.. but probably didn't need a d60 in the first place. Also throwing in an unused Warn hub for 30 spline d60. He has a set of rear doors that are in good shape dent wise.. but wont open. if i can help him get them open and depending on the shape of the bottom... wouldn't mind getting my hands on those. He sold the frame so just the crew cab "cab" left.
Old Jun 9, 2020 | 06:06 PM
CumminsCrew74
Anyone purchased anything on Bronco Graveyard? Seems like a solid price for a full set.
https://shop.broncograveyard.com/D60...BoCbDgQAvD_BwE
Old Jun 9, 2020 | 06:33 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you can get the outer door panel off (very carefully of course) and then remove panel 23220 or 21130 and see if you can pull on rod # 21940 to release them?
Old Jun 9, 2020 | 06:46 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Definitely easier to move when empty. While it is empty, I drilled a drain hole in the bottom of the case and put a 1/4 pipe plug in for a drain. Just tapped it deep enough to get plug below the housing.
Old Jun 10, 2020 | 09:32 AM
mark a.'s Avatar
mark a.
Originally Posted by speedfreak78
I'm pretty sure the 78/79 drivers side lower plate is unique from the others, it's the one you always see people looking for. They're usually selling in the $120-150 range on Ebay. Sets only go for $20-50 more because the pass side plate is the same up to '97.
Did the rust eat a big void into the casting around that seal? Is the seat face scored? If it's just a void, it shouldn't matter, as long as the shims and bearings can still seat correctly and the seal has full contact. A little RTV around the new seal should take care of any gaps.
Nope, drivers side is the same between 60 & 44. I've got plenty of them around here.
Old Jun 10, 2020 | 09:53 AM
speedfreak78's Avatar
speedfreak78
Is probably a location thing just like the D60 front axle, North/East no problem finding them, South/West they're gold.
You should put any extras up on eBay for $100/ea, you'd undercut everything I saw and you could make a quick buck or two.
Old Jun 10, 2020 | 09:55 AM
Another66's Avatar
Another66
I don't know if there was some variations or what, but when I replaced my 44 in my 78 with a 60 from a 79 that drivers side plate was different. At first I thought I was screwed but the axle had come with some misc. parts in a box, and it was in that box. What a relief it was to find it.
Old Jun 10, 2020 | 12:28 PM
fordrealdrive's Avatar
fordrealdrive
Deleted...
78ShortBed-
54
Mar 10, 2023 11:59 AM
twtomt15
20
Apr 29, 2020 10:03 AM
Antal
1978 - 1996 Big Bronco
Nov 21, 2019 10:50 AM
spikinfool05
38
Aug 24, 2014 06:23 PM
ManfredVonRichtofen
39
Jun 26, 2012 12:22 PM
