Coolant Additive Test Strips
Old Jun 6, 2020 | 11:32 AM
55 BelAir Wagon's Avatar
55 BelAir Wagon
I just got this message on my 2015 6.7L. I read that it is just a run time reminder to check the coolant condition. Where do you guys get your test strips to do this? What are the best ones to get? Thanks in advance!
John
Old Jun 6, 2020 | 02:41 PM
seville009's Avatar
seville009
Bunch of threads.....here’s one
https://www.ford-trucks.com/forums/1...ant-tests.html
Old Jun 6, 2020 | 03:29 PM
55 BelAir Wagon
Thanks, Seville009. That answers my questions!
John
Old Mar 22, 2022 | 02:05 PM
tradosaurus's Avatar
tradosaurus
$9.95 for 4 strips and $11.95 for shipping. Not happening.
Old Mar 24, 2022 | 05:10 AM
jsukey's Avatar
jsukey
The new coolant doesn't need to be tested FYI. If it's getting close to the scheduled time to change it, I would go ahead and spring for the flush with the yellow and call it a day.
Old Mar 24, 2022 | 11:42 AM
tradosaurus
I had the coolant changed at 130000 miles when my radiator was replaced. I think the coolant is red. I got the "Check Coolant Additive" message.
Old Mar 24, 2022 | 11:45 AM
jsukey's Avatar
jsukey
The new coolant is yellow. The previous coolant was orange. I don't think Ford is even selling the orange coolant anymore. Once you go yellow, you never have to worry about testing it again.
Old Mar 24, 2022 | 01:22 PM
tradosaurus
I'll check the radiator fluid color to make sure.
Old Mar 24, 2022 | 01:35 PM
jsukey's Avatar
jsukey
What you may be seeing is the orange and yellow coolant mixed together. When I picked my truck up from the dealership after the coolant flush, I immediately popped the hood to make sure that it had been done. What I saw was a neon pink color in both of the coolant reservoirs. I asked them to do it again, because it obviously hadn't been flushed. When I came back the second time I inspected again and found a slightly more yellow colored coolant. I started to question the tech's experience and was told that they let it drip out for an hour. I explained to them that was not a "Flush", but merely a drain and refill. They told me it would run around $800 I think, in order to do a full flush. I told the SA that he needed to explain that from the get-go. They can't charge for a flush if they aren't going to actually flush it.
Old Mar 24, 2022 | 04:05 PM
tradosaurus
Yellow and orange make green or a light orange depending on how much you put in of each color. I am now interested in what color my radiator fluid is. I have to wait until after work.
Old Mar 24, 2022 | 04:21 PM
jsukey's Avatar
jsukey
I would think there would definitely be more of the new yellow coolant in it after draining the radiator and secondary cooling system from the bottom side. I can't tell you how diluted they were. I took a quick pic of it after the 2nd "flush" that they did. It definitely looked bright pink. I had ordered the new yellow coolant to save a few dollars, so I can verify that it was the new yellow.
Old Mar 24, 2022 | 07:35 PM
tradosaurus
Well Kemosabes it looks like my coolant is blood red.
Old Mar 25, 2022 | 04:53 AM
jsukey's Avatar
jsukey
I've got nothing! Lol
Old Mar 25, 2022 | 10:28 AM
djousma's Avatar
djousma
So, here is my take on the testing. First off the notice comes up just like change oil soon. There is a reset in the menus to make that go away, at the same place as the fuel filter reminder. In my 2011 i was **** about testing the coolant, never came up bad. I personally dont test it any more, and if I did it would only be after service to the cooling system was done, or some other major event.
Others will likely disagree, and thats fine. My point is that it is nothing to fret about if you skip it occasionally.
Old Mar 25, 2022 | 10:43 AM
C12H24's Avatar
C12H24
Depends upon what you are testing. If you are testing for coolant to water mix, that normally doesn't change over time if you're not adding to it or losing any. A refractometer will show you that. The freeze and boil-over protection is nearly forever. There is also a lubricant for the water pump bearings and seals. That's a pretty sturdy additive. The one additive that is consumed is the corrosion inhibitor. It is consumed because the liquid acts as an electrolyte and as the various metals swap electrons, they degrade and corrode. The additive stops this and is consumed in the process. The test strips will show you that as a change in acidity in the liquid. I keep test strips around and test brake fluid and coolant every year.
Bohen
6.7L Power Stroke Diesel
Mar 20, 2020 06:01 PM
tdpower
15
Mar 1, 2011 11:39 PM
quaders4ever97
Dec 17, 2008 01:29 PM
camdaddy
Mar 13, 2007 09:53 PM
tjbeggs
Jun 29, 2004 09:03 PM
