Sponsored by: Auxito
2001 starting issue
Old Jun 5, 2020 | 04:56 PM
dumdum9599's Avatar
dumdum9599
2001 starting issue
Hello all I have a 2001 with the 4.6 liter engine and it has difficulty starting when warm first start of the day is fine evey other start that day it will take longer and I have to hold the gas to the floor to get it to start. It is getting lots of gas. I have put new fuel pump in and completely cleaned out the gas tank as well as new filter and had the injectors replaced new spark plugs and coils. And it runs perfectly fine once running and all speeds not starving issues. Any help would be appriciated.
Old Jun 6, 2020 | 08:26 AM
Bluegrass 7's Avatar
Bluegrass 7
Flooring the throttle 'shuts' off the fuel.
Check fuel pressure for being excessive. Should be not more than 40 psi at anytime. Use gage on test port.
Other causes of excess fuel;
#vacuum leak has shifted the fuel tables rich,
#Thermostat stuck open,
#temperature sensor faulty,
intake air control sticks closed. Low hot idle would be the indicator..
Use a Scanner to look at these areas # for being out of limits..
Old Jun 6, 2020 | 10:12 AM
dumdum9599's Avatar
dumdum9599
Thermostat is new idle is perfect no vacuum leaks. Will check fuel pressure and I would think a faulty coolant temp sensor would mess with the idle
dumdum9599's Avatar
dumdum9599
Also to not note short and long term fuel trims look good
Old Jun 6, 2020 | 10:43 AM
alloro's Avatar
alloro
Originally Posted by dumdum9599
it has difficulty starting when warm first start of the day is fine every other start that day it
By warm to you mean the weather? Does it start right up in the cool weather?
Old Jun 6, 2020 | 12:36 PM
dumdum9599's Avatar
dumdum9599
No not weather just when truck is warmed up it starts right up on the first start of the day or when it sits for over 3 hours
Old Jun 6, 2020 | 12:48 PM
steve(ill)'s Avatar
steve(ill)
Bluegrass mentioned temp sensor.... Different animal, but i had an older Explorer that would not start when hot... Looked at everything like you said.... Bluegrass mentioned temp sensor.. and i DID have a code for that but was paying no attention... When the motor is HOT the computer does not " choke" to start... When COLD you need excess gas to start ( think of how an old carburetor car works)...... If your TEMP sensor is not working, the computer can put EXCESS gas into the system because it thinks it is a COLD START UP.................... If you think about it, it makes sense.
Old Jun 6, 2020 | 04:15 PM
dumdum9599's Avatar
dumdum9599
I had thought of that also but generally when the temp sensor begins to fail it will cause problems idling. But my truck idles perfectly and I did look at the temp sensor PID on my scan tool and it looks fine
Old Jun 6, 2020 | 05:07 PM
Bluegrass 7
It is possible the Crank Sensor plug is dirty and needs re-seating and is temperature sensitive from engine heat.
If this sensor circuit goes open, nothing will work but the fuel pump priming on any ignition On cycle that does not depend on the Crank Sensor for initial pump priming.. This would mean no ignition or fuel injection at cranking.
You have to find the root cause of the issue. Either fuel or ignition first, then pursue that direction.
Are the plugs wet with fuel?
Is ignition missing?
Only difference between cold and hot starting is the temperature of the Cooling system and the Intake air temperature. It's the only way the PCM has to know the difference.
The issue has to be centered on the warm/hot start system signals.
The supporting differences are amount of fuel commanded, ignition timing and IAC opening. The Ox Sensors don't come into the act until they get up to temperature after the motor starts..
Old Jun 6, 2020 | 06:50 PM
pdqford's Avatar
pdqford
While you’ Checking stuffs, I’d also check the fuel pressure regulator at the fuel rail. Be sure it vacuum hose is fully connected with no soft spots and that there is no fuel in the vacuum hose.
neil1218
Feb 8, 2011 03:56 PM
Odd_Ball
Nov 26, 2010 09:41 PM
skrullb
1997 - 2003 F150
May 23, 2010 08:58 PM
diesel2008
Nov 29, 2007 05:18 AM
f1drivr
Oct 4, 2003 12:13 PM
