Starting Problem
Old Sep 22, 2003 | 02:01 AM
f1drivr's Avatar
f1drivr
Starting Problem
Ok, I have a 1990 Mustang GT EFI engine in a 1951 Ford Truck. It's been sitting for about 1.5 years while I 've been doing a body off paint job. It ran great when I parked it. Now when I try to start it , it just turns over & want start. If I squirt some gas in the intake it will fire up on the first lick & will start first lick all day, Once it is warmed up. But if I try the next day, Same thing I have to squirt some fuel in the intake. So far I've put a new fuel pump on it, a new adj fuel pressure Reg set at 43 with the Vac line off & around 38 with the Vac line on. It was doing the same thing before I changed the PSI Reg. Any Ideas????
Old Sep 22, 2003 | 08:25 PM
LxMan1's Avatar
LxMan1
Starting Problem
Sounds like the gas is starting to sour. They are hard to start and don't run so good when cold when the gas is losing it's potency.
Jimmy
Old Sep 22, 2003 | 10:06 PM
f1drivr's Avatar
f1drivr
Starting Problem
I drained the gas, replaced the fuel filter, filled tank with 93 octane & injector cleaner. It still did not start without being primed, But it ran smooth & has started up every time so far. I'll try it again in the morning. Thanks for your post
Old Oct 3, 2003 | 12:55 PM
f1drivr's Avatar
f1drivr
It's fixed
It was the gas!!!!! I've went though 3 eletric in tank fuel pumps, 2 Computers, a new fuel psi Reg!! & all it was sour gas the whole time. Thanks for the help.
Old Oct 4, 2003 | 12:13 PM
LxMan1's Avatar
LxMan1
Glad to help.
Jimmy
