Driver side rear window motor
Old May 29, 2020 | 09:23 PM
derek0525's Avatar
derek0525
So looking on rockauto for the left passanger rear window motor cant find the motorcraft one is the front right side the same as the left rear I see they have one for the left front and right rear as same part number so im guessing its the same but wanna double check.
Old May 30, 2020 | 12:00 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
When I am unable to find an OEM part, I usually get in touch with Tasca (https://www.tascaparts.com/) via phone and either order from them or go to Riffraff or Disiel-o-rings.
Old May 30, 2020 | 06:37 PM
derek0525's Avatar
derek0525
Tasca parts wants 38 bucks to ship thats insane.
Old May 30, 2020 | 10:11 PM
Sous's Avatar
Sous
FTE Emeritus
Did you get the information you were looking for?
Like I said, I usually go with a different supplier than Tasca, but they are good for getting part numbers. If you got the information you needed, then you are having a good day regarding your question.
Old May 30, 2020 | 10:48 PM
derek0525's Avatar
derek0525
Nope cant find just the motor on there guess just end up calling someone monday.
Old May 30, 2020 | 11:25 PM
Sous's Avatar
Sous
FTE Emeritus
I believe I mentioned that very tactic above... Good luck to you.
Old May 30, 2020 | 11:28 PM
derek0525's Avatar
derek0525
Yeah was wanting to have it by monday was the issue wont have a day off for few months but yeah thanks.
Old May 31, 2020 | 07:23 AM
Dan V's Avatar
Dan V
LMC Truck
https://www.lmctruck.com/1999-16-for...oor-components
BabyFutaGrlAlice
May 17, 2020 08:58 PM
spacely
1978 - 1996 Big Bronco
22
Jan 16, 2007 02:47 PM
catman52987
Oct 11, 2006 08:19 PM
