Paint removal
Old Oct 17, 2003 | 05:34 PM
BAMF82's Avatar
BAMF82
Paint removal
I swapped paint with a pole in a parking lot. Luckily, I didn't dent my fender, but now I have a strip of white paint on my truck from the pole. What is the safest way to get off? My truck is hunter green.
Old Oct 17, 2003 | 06:09 PM
Aekisu's Avatar
Aekisu
<cr>
Sort of depends on the paint. If I have a urethane that is well cured, a little lacquer thinner on a rag usually takes care of the problem. On the other hand, if the paint is a lacquer (which is rare now a days) or an enamel, that some light buffing coumpound will usually do it. If you use lacquer thinner, be careful. The stuff can skin enamel off of teeth I swear.
By the way, you have a dent if there was paint transfer. Just not a big one.
Old Oct 18, 2003 | 08:12 AM
BAMF82's Avatar
BAMF82
my truck is a 2001, so it should be well cured and it "should" be urethane. I also read somewhere to try gas. Should I try gas first?
Old Oct 18, 2003 | 01:55 PM
Aekisu's Avatar
Aekisu
<cr>
Your truck is a urethane unless it has been repaintd with something else.
I'm not a big lover of gasoline for anything except fueling my engine. You might give it a try though and see how it works.
Whatever you decide to use, proceed with care and take your time.
Gage2502
Jul 6, 2016 06:19 AM
BTJ350
Mar 1, 2015 10:29 AM
awillo0406
Jan 16, 2014 07:20 AM
GRNMSTR
2004 - 2008 F150
Apr 16, 2010 09:34 AM
Munkey
Mar 21, 2005 07:31 PM
