1 wire alt..
Old May 27, 2020 | 06:41 PM
AnotherChef's Avatar
AnotherChef
1 wire alt..
I changed to a 1 wire alt months ago... but, the connection point grounds out to the block and makes the belt squeal like crazy!!!! Which alternator did yall use??
Old May 27, 2020 | 06:45 PM
ford390gashog's Avatar
ford390gashog
The 3g swap is preferred and easy to do.
Old May 27, 2020 | 08:10 PM
F-250 restorer's Avatar
F-250 restorer
I use a 130 amp alt that came in a 94 ford Taurus. It bolts right in. But I did have to remove the three long housing bolts that hold the front and back housing to the core. Once they were out, I rotated the back until the wires were down, and reinstalled the three bolts. I also had the squeal problem that you mention, but switched to a two v belt pulley, and the problem vanished. BTW, there's a great 3g alternator rebuild video on youtube. Once you see it, you'll never buy a 'rebuilt' again. Good luck.
old and new. You'll swap the pulleys over.
you'll lose all this below:
You'll need to add one of these, a 175 amp fuse.
Something like this:
Old May 27, 2020 | 11:53 PM
1TonBasecamp's Avatar
1TonBasecamp
Not sure what you mean by that exactly. Can you put up a pic of the offending connection points?
The actual point of touching is supposed to ground the alternator case to the engine block. Then to the battery through the main ground cable connection. But if something on the back is touching, that's not exactly a "good" thing, but I don't see how it would cause the squealing.
In fact, belt squeal is a known commodity with some modern high-output alternator swaps. I hear more people complain about it with Ford alternators than do with GM versions, but not sure why. Haven't tracked the issue with 1-wire alts though, and was just discussing it today in a "meeting" wondering if 1-wire alts were as susceptible as 3-wire alts were.
F250 restorer's solution was the same thing I did on my Bronco. My F350 on the other hand, did not need it. I believe that it's due to the pickup's larger diameter factory pulley vs the smaller one that came on the Bronco.
A dual-groove pulley solved the issue. On the other Bronco I've got an Explorer serpentine conversion so it's never an issue on that one.
Out of curiosity then, which alternator did you go with? Love to see some pics.
Thanks
Paul
Number4
32
Nov 11, 2017 05:19 PM
Mixer man
16
Apr 21, 2015 07:06 PM
DR Smith
Nov 23, 2013 04:35 PM
62UniF100
Oct 13, 2010 02:02 AM
SleeprLegend
15
May 6, 2010 10:28 PM
