Spare tire mount
Old May 26, 2020 | 06:19 AM
Sosha's Avatar
Sosha
Spare tire mount
night out
Looking for a spare tire mount. If anyone can help me find one for a 64 F100 it would be much appreciated.
Old May 26, 2020 | 10:46 AM
daveengelson's Avatar
daveengelson
Great looking truck!!
I installed an under the bed spare tire rack on my 65 flareside 6 1/2' bed, this was many years ago while salvage hunting went along the rows of Ford trucks until I came across one, unfortunately, I can not recall the year, believe would work in to the mid to 70's Ford trucks, I also have dual pipes coming out the back? Perhaps another member will chime in with info? I may have an extra however the cost of shipping is ridiculous. Suggest check out a couple of salvage yards, in Ca. there is Pic n Pull and they have a website where one can list the vehicle and it will list all the yards with the particular years one is looking for.
Old May 26, 2020 | 02:06 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Below is link to another under bed spare mounting option. Although, I always thought the outside bed mount on the flare side looked good and maybe that’s what you are looking for. Good Luck.
https://www.ford-trucks.com/forums/1...6-f-100-a.html
Old May 26, 2020 | 02:23 PM
daveengelson
Agree about the side mount, kept mine intending, oh soo long ago, to reinstall once the original indented fender is repaired.
Old May 26, 2020 | 06:19 PM
Sosha's Avatar
Sosha
Thank you for your help. I'll take it under advisement. Your right though, I I am looking for one that'll fit on the flareside but you have a really good idea to, thank you again
Old May 27, 2020 | 09:17 PM
RangerMercMan's Avatar
RangerMercMan
To mount on the Flareside shortbox you will have to change the fender
Old May 28, 2020 | 02:06 AM
Sosha's Avatar
Sosha
Spare tire mount
Thank you , I didn't know that. I suppose I'm going to leave it like it is then and just put the spare tire in the bed of the truck. Thank you very much for your time.
Old May 28, 2020 | 10:47 AM
rdixiemiller's Avatar
rdixiemiller
Spare tire mount
I'm going to hit a Pick and Pull and get a Dodge spare tire winch. The old style underbody racks are a pain to me. The miniature chain hoist style that are currently used are much easier to use. In my opinion.
Old May 28, 2020 | 10:54 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Yeah, my 1999 Dodge Ram has a cable lift with a crank just below the tailgate. They are very slick (no pun intended) and I believe a Ford spare tire hoist will fit as well with a little ingenuity. Someone on here did one on their 66. Since our frames are generally narrower than newer trucks with a hoist the cross-member that holds the hoist just needs to be shortened some. This setup probably wouldn't work with a rear mounted gas tank since the hoist and tank would be fighting for space.
Old May 28, 2020 | 11:25 AM
daveengelson
Actually, over the past 45 plus years, I can count the number of times I have had to drop the spare once or twice and did not find it took an excessive amount of strength, once the tire is set in position, similar to a pendulum, just a matter of swinging the tire rack in place, the retainer inserts thru the rack and easily snaps into place admittedly not going to try and hold it in place for an extended period of time, anyhow, what am I paying road service for?
Old May 28, 2020 | 11:54 AM
rdixiemiller
I still have the cab mounted tank, so no space issues. I also run 235 75 R15 tires, so not too terribly big.
Old May 28, 2020 | 11:55 AM
rdixiemiller
It's not the weight, they tend to drag when driving down dirt roads with deep ruts. When I was a kid, pulling the stock spare tire mount off happened pretty quickly, the first time it got you stuck. The channel frame under the tire makes a pretty effective anchor. It will also double as a scrape blade, for leveling out the center of a sand road with fairly deep ruts. I believe it hangs down about 1.5 to 2" below the spare tire itself.
riksolo
1947 and Older Ford Trucks
Oct 23, 2023 11:24 PM
slabhunter
16
Jul 30, 2022 12:43 AM
Sosha
May 26, 2020 06:17 AM
lakeboater
15
Mar 11, 2020 07:58 AM
ole yeller 1978
Apr 27, 2006 03:12 PM
