Howdy, I usually hang out on with the 51 ford group. Can you guys help.me with this VIN number. It is from a 70 ish F700 dump truck. What I am mainly after is the size of the engine e. Any help is appreciated .
vIN # F70EVHB1196
Howdy, I usually hang out on with the 51 ford group. Can you guys help.me with this VIN number. It is from a 70 ish F700 dump truck. What I am mainly after is the size of the engine E
VIN: F70EVHB1196
Edit: Looking at the pic, this is a Bumpside (1967/72 truck). Bumpside hood side emblem w/yellow reflector: 1968/72.
This serial number (last 6 digits of the VIN) decodes to a 1980 F700, but there was no E 4th digit VIN engine code after 1978, no Bumpsides after 1972.
So the H may be correct, but the B is probably the number 8 // H81196 = 1970.
After I posted that I couldn't keep but wondering about that "B". I will check it out today but I believe you must be correct. I will set you know. Thank you for the help. What you do here for all of us makes a differance.
Dave C
