Engine harness bolt together plug swap
Old May 20, 2020 | 12:45 PM
Dan Drover's Avatar
Dan Drover
I'm doing an engine swap 300-6 to 351w the 351 has a obd2 harness and the truck is obd1 i have a obd1 harness for the 351 but the bolt together connector on the truck is square and the one for the harness is round.
I'm trying to find a diagram that shows the colours and locations the pins need to be in so I can swap the round plug for the square one. Does anyone have one or know where to find it?
Or would it work to simply colour match the wires on the two sides? As I have yet to see a diagram that shows the bolt through connector.
Old May 20, 2020 | 01:09 PM
Franklin2's Avatar
Franklin2
Tell us what year and model the truck is, and what year and model the engine you are swapping in is from. On the later models, f150 or f250/350 superduty makes a difference.
Old May 20, 2020 | 01:12 PM
Dan Drover's Avatar
Dan Drover
351 came out of 96 f150 going into 93 f150 have the 351 obd1 computer installed in the 93
Old May 20, 2020 | 01:46 PM
Franklin2's Avatar
Franklin2
On the older trucks, the computer system and wiring was separate from the rest of the truck except for just a very few spots. If you had the obdi engine harness to go with the computer you have, I think you could do it fairly easily.
Old May 20, 2020 | 02:00 PM
Dan Drover's Avatar
Dan Drover
This is what I really need to know
is there a diagram or are the wires the same colour on either side of the plug
Old May 20, 2020 | 04:17 PM
Franklin2's Avatar
Franklin2
I am not sure what plug you are talking about, but I am sure some of the wires are the same colors and some are different colors. Yes there are diagrams, I don't have access to any for free. You will have to buy them, the best place is ebay.
Dan Drover
May 21, 2020 11:48 PM
Jrock909
May 23, 2007 08:55 AM
FordMan24
Engine Swaps
Feb 3, 2006 11:34 PM
radramrod2
Jan 31, 2005 05:01 PM
bronconut
Engine Swaps
Aug 2, 2004 10:50 PM
