Brake light switch?
Old May 19, 2020 | 10:12 PM
harley7991's Avatar
harley7991
Brake light switch?
Finally have the 66 back on the ground with disc brakes
For those of you who have done this upgrade, what parts have you used to get the brake lights working? The factory setup only had a pressure switch on the master cylinder...
Old May 19, 2020 | 10:39 PM
resonateur's Avatar
resonateur
I took the brake switch off a '74, drilled a hole and keyway in the brake pedal bracket and wired the switch in. Any momentary switch would work as long as you can find a way to mount it to you brake pedal so that the brake pedal arm actuates the switch. In my case, when the pedal is depressed, the plunger on the switch moves outward, closing the contact and providing 12 volts to the brake light circuit. There would be a number of ways to do this and some providers of restoration supplies make kits to change from hydraulic to mechanical switches.
Old May 20, 2020 | 06:39 AM
harley7991's Avatar
harley7991
That's helpful, do you have picture?
Old May 20, 2020 | 06:58 AM
jowilker's Avatar
jowilker
I pulled the wire back into the cab and made this https://cimg7.ibsrv.net/gimg/www.for...34d901c0ae.jpg
John
Old May 20, 2020 | 07:02 AM
robertrpeak's Avatar
robertrpeak
I did mine like John. took about an hour of time and just a couple dollars!! Bring it to Tellico and I'll help ya.
Old May 20, 2020 | 07:41 AM
harley7991's Avatar
harley7991
Thanks for the input and offer. Truck still has a ways to go before getting on the road. PO things to fix:
- cut steering column
- rear diff not secured
- electrical is a disaster
- driveshaft has 2 sliding yokes, so the carrier bearing walks out of the support
Where could I find a bracket for the switch, or do you just make one?
Old May 20, 2020 | 10:09 AM
resonateur's Avatar
resonateur
Harley:
I'll try to get a photo later...but John's set up is certainly easier with the bracket bolted to the brake pedal bracket. Mine is mounted on top of the pedal bracket, but I had the bracket out of the truck which made drilling the hole in the right spot pretty easy.
Old May 20, 2020 | 10:38 AM
cosmofennema's Avatar
cosmofennema
I used a Ford brake switch from a later model. Ford used these switches for decades.
They mount around the pushrod, and actuate when the pedal is pressed.
Simple, no mounting bracket necessary, and any parts store everywhere, including every Ford dealer, has them in stock.
Old May 20, 2020 | 12:26 PM
harley7991's Avatar
harley7991
This switch? 13480 I think...
Old May 20, 2020 | 01:04 PM
robertrpeak
I use to run that switch, but after awhile they start sticking well at least the five I tried did. This is the one I use now.....
https://www.performanceonline.com/br...nting-bracket/
Old May 20, 2020 | 01:37 PM
BobbyFord's Avatar
BobbyFord
I made some small brackets and used a Standard SLS66 switch on my ‘63.
Old May 20, 2020 | 02:49 PM
Thunderkiss1965's Avatar
Thunderkiss1965
That switch is a major PITA to install up under the dash where it needs to go.
Old May 22, 2020 | 05:07 PM
harley7991's Avatar
harley7991
FYI - I cut a piece of angle and made this:
MartyTheOneManParty
May 14, 2016 10:40 PM
Shane Carruth
May 7, 2016 06:19 AM
syannuzzi
Electrical Systems/Wiring
Dec 28, 2006 09:54 PM
jrw429
1966 - 1977 Early Broncos
Dec 3, 2003 10:53 PM
leonharu
Jun 26, 2002 10:03 PM
