The Addiction
Old May 22, 2020 | 08:03 AM
  #31
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Listor, just to close the loop on my suggestion for you a bit in case you were not familiar with the procedure for looking up the PCM code via Forscan, I have provided a link below.
https://www.ford-trucks.com/forums/1...l#post19259763
Keep us updated...
Old May 22, 2020 | 10:33 AM
  #32
Listor's Avatar
Listor
Keep us updated...
I got it going again, i did notice when i changed from 00 to 01 it would hesitate, i think because they are both stock settings
i forgot that 00 was already a stock setting, so i have adjusted the program list accordingly, going to find out what the whisper does
It seemed like maybe i tugged the chip a little, i pushed it in some and everything was fine, was to tired last night to consider that!
And again i have to thank all of you guys that have helped me with your awesome advice, you rock!
Old May 22, 2020 | 10:44 AM
  #33
RacinJasonWV's Avatar
RacinJasonWV
Isn’t the PCM code also on the black plastic plug you remove when adding the chip? Just a thought.
FYI as you probably already know, the PCM must be free of all the silicone. Tricky thing knowing when is enough but not too much cleaning. I’m sure I fell into the too much category.
I think PHP has their own video on how to clean the contacts.
Old May 22, 2020 | 10:50 AM
  #34
RacinJasonWV
Oops we were posting at the same time.
Please do not adjust the chip while it’s running. Not saying you did that, but just wanted to throw it out there for safety sake.
The 00 setting is what I was trying to express the other day but didn’t communicate it very clearly. There should also be a “ns” or such above all the numbers for no start.
Anxious to hear your review.
Old May 22, 2020 | 12:26 PM
  #35
Listor's Avatar
Listor
so from what have read 00 is set to stock and 15 is set to no start , I have actually been running the 40 hp daily driver tune , omg it’s amazing ,will no doubt mess with others just for fun 🤪
Old May 22, 2020 | 12:27 PM
  #36
Listor's Avatar
Listor
I must say it’s very gratifying to see the hard work pay of with positive results! Taking the better half to Costco, lol she’s gonna freak
Old May 22, 2020 | 12:57 PM
  #37
RacinJasonWV
Awesome! Glad to hear you’re happy with the outcome and reaping the benefits of all the hard work.
FYI you should be ok on EGTs for some short fun bursts even without the gauge.
Careful not to scare your passenger too badly.
Old May 22, 2020 | 01:01 PM
  #38
RacinJasonWV
Oh, and I was thinking mine would read “ns” at the top setting but I’ll trust what you’ve read recently over my memory.
Someone correct me if I'm wrong but I also think that any slot you leave empty will act as a no start.
Old May 22, 2020 | 02:43 PM
  #39
Sous's Avatar
Sous
FTE Emeritus
00 - is stock
NS - No start
These are built into the Hydra programming and can be found by cycling through the different selections. If a slot is left empty, the Hydra will skip to the next programmed spot. For example, if 3 was a tune and 7 was a tune but 4, 5 and 6 were empty, it should skip from 3 to 7 when changing the selection.
Listor, based on your printout above, you appear to have "dead pedal" in spot 15. This is different from "NS" because the NS tune will not allow the truck to start. It will crank, but it will not start. With dead pedal, the truck should start, but the accelerator will not command fuel to the engine.
Old May 23, 2020 | 06:52 AM
  #40
Listor's Avatar
Listor
LOL the wife freaked out yesterday going to costco, I jumped on the freeway just to pass someone LOL
She says what the hell did you do to the truck, i said fixed it! she said wow you did a great job, didn't know a big *** truck could move like that
You should have seen the smile on my face!
Old May 23, 2020 | 07:02 AM
  #41
Listor's Avatar
Listor
00 - is stock
NS - No start
I have since moved things around, 00 is stock, 15 is no start , I am having a couple of glitches, everything was working fine was sitting in the line at the carwash and it just died
i switched to 00 and cycled the key fire right up, get back to the house switched back to 02 cycled the key and fired right up
so i am going to pull it all apart today as i have some time, make sure i got all that crap off the connection
Old May 23, 2020 | 08:15 AM
  #42
RacinJasonWV
That’s awesome! And just the 40hp tune?
“I swear hunny, just needed maintenance items.”
It is really nice to get the 3rd party unbiased confirmation of your work. My wife is oblivious to any truck stuff so when she notices a difference it means it is real.
I think you’re heading in the right direction here. My feeling is that you have a poor connection to the PCM. This can end badly with a fried PCM from what I understand. I would make this my 1st priority.
Old May 23, 2020 | 09:00 AM
  #43
Listor's Avatar
Listor
thanks , just gotta slow down and take it by the numbers
Old May 23, 2020 | 09:54 AM
  #44
Listor's Avatar
Listor
Hmm seems I am getting a lot of codes now
p0683
po670
u1262
p1000
po603
po470
forscan tells me the strategy is TNAA753 That’s not what the hydra software told me TNAA4N2 is what it said is that an issue? how do i redo and get the suggested tunes just want to make sure i am selecting the proper ones
no engine light
its interesting for sure I can clear them but they come right back
oh well I will pull everything and start all over
Old May 23, 2020 | 11:30 AM
  #45
Listor's Avatar
Listor
btw i see my glitches now, had a different category tune in there, so many to chose from LOL
