Sponsored by: Real Truck
Wheel/axle assembly
Old May 18, 2020 | 10:23 AM
MTP55's Avatar
MTP55
Wheel/axle assembly
Truck is a 2000 F250. Trying to put the axle and hub back together on the front end. My problem is when I go to put the three washers and one snap ring back on the groove for the ring is still under the washers. Almost like the axle is too far in. There is a small groove in the knuckle, I dont remember if the race for the seal is supposed to sit in line behind or in front of that groove. Anyone know?
Old May 18, 2020 | 02:52 PM
99f350sd's Avatar
99f350sd
Where is the plastic washer? who mashed the seal? not good.
put axle in.. put washer on.... grooves facing inward w/grease. next grease bearing and bolt bearing up.
put in 3 washers metal in middle..if you can't put clip on try to pry axle out from ujoint area...
Old May 18, 2020 | 02:56 PM
MTP55's Avatar
MTP55
put axle in.. put washer on grooves facing inward w/grease. next grease bearing and bolt bearing up.
the seal is fine for the most part, those are just dings in the surface. It appears that somehow we got it 1/16" too far in and now it wont come back out. The outer rubber piece refuses to slide. I tool the washer off while I was working on it.
Old May 18, 2020 | 05:09 PM
99f350sd's Avatar
99f350sd
I grease the whole place where the seall goes in case it has to come apart again.
Old May 18, 2020 | 05:32 PM
MTP55's Avatar
MTP55
yeah I'm going to do that on the passenger side. Turns out the passenger side had a wrecked needle bearing not the drivers like I thought. Also found the plastic thrust washer broken. And
as luck would have it no parts stores even know what it is. I'd imagine it's a poor idea to try and "fix" it.
Old May 18, 2020 | 07:58 PM
99f350sd's Avatar
99f350sd
Dealer part or maybe ebay.
Old May 19, 2020 | 08:26 AM
MTP55's Avatar
MTP55
dealer was not overly helpful but I did get one ordered from a heavy truck repair shop that should be here by noon tomorrow. Hopefully he said $5 a d not like $35 haha.
bentmetal
Escape & Escape Hybrid
Aug 14, 2012 12:27 PM
blake2182
May 30, 2011 09:06 AM
VodkaMan
Aug 15, 2009 12:39 PM
bigtuna128
Apr 9, 2009 12:59 PM
Mac 25
Aug 23, 2005 11:28 AM
