3.5EB Swap
Fairly new member here, but have been reading around this forum a lot over the past few weeks. I've got an 02 high mileage Excursion that I purchased for a little of nothing. Its a V10 (305hp, 420tq) truck, that at the time of purchase I had the intention of doing a Cummins swap with. However, I'm now considering a 3.5EB with either the 6R80 or 10R80 from an F150. The power is well in excess of stock, without any tuning. There doesn't seem to be a lot of information readily organized regarding this type of swap, and was hoping to get some guidance.
1. Plan on purchasing the entire drivetrain, however I cannot determine whether I'll need any of the other electronics from the truck besides the ECM and TCM. (BCM?)
2. I've read about some great tuners, anyone have any recommendations for someone that has worked on this style of swap?
3. What are the thoughts on the 6R80 vs 10R80? I built a spreadsheet for final drive ratio with different tire sizes and rear ends, don't think it's going to matter from the gearing perspective. Planning on 3.73 with 35's, more than likely upgrading to dana 60's from the 05-10 truck.
4. Plan on reusing existing transfer case, with as much of the original body control functions.
5. Would you use an aftermarket EPAS on this size of a vehicle, or add a power steering pump to the EB? Anyone added a power steering pump to an EB?
Thanks
Hoodlum
Have you been through this thread? Sure, it's focused on older trucks, but might be worth a look.
https://www.ford-trucks.com/forums/1...-79-truck.html
Here is what you should do because I'm helping you spend your money. Right now on ebay is a couple of Raptor 3.5 Eco's with 450 horse and 500 torque for $5500 that have an advertised zero mile takeout due to upgrading to a Supercharged V-8. Get that, a 6r80 or a 6r100 which would be better for your excursion (found in F250's with the 6.2L gas engine) and that superduty T-Case I mentioned and you will most likely be the only one in the world that has that combo. Remember I'm always here to help you spend your cash!
The pic has the Superduty T-Case 2017 (no slip yoke) and a 2011 F150 T-Case for comparison
https://www.stinger-performance.com/...rness-telorvek
https://www.ebay.com/itm/2019-Ford-R...7d90%7Ciid%3A1
Thanks for the input.
The Excursion is a heavy duty SUV that is based off of Ford's Super Duty F-Series 3/4 and one ton platform. It was a vehicle that was intended to cater to those who desired an SUV but needed the capability to tow or haul the weight in the range of requirements of a 3/4 ton truck. The power train options for that truck was therefore spec'd accordingly. Ford's 3.5L Ecoboost V6, while proven to be a very desirable engine choice by many for quite a few F-150 owners since it's release beginning with the 2011 model year to present, has never been equipped in any of Ford's trucks of greater than 1/2 ton. For this reason alone, I would question the feasibility of the intended swap.
Lastly, for the amount of work and money needed to even think of committing to an undertaking of this magnitude, how much of a difference are you away financially from simply just getting into a newer Expedition that comes from factory equipped with the 3.5L Ecoboost V6, and 10 speed auto that you desire if you get into an '18? Will an Expedition described above, meet your needs while at the foregoing the headache of a major powerplant surgery?
Agree that a current expedition may be cheaper. Not really concerned about it though because I've always wanted the Excursion. Just not a huge fan of diesel, and the V10 drivetrain doesn't do it for me. I haven't found a powertrain that is more prevalent, or cheaper, for the amount of performance that is achievable. Plus the internals are designed for boost, whereas a coyote, 6.2, etc aren't and the only way to achive that power is with forced induction.
Shoot more holes through it, That's why I was looking for opinions on this.
Thanks,
Regarding the manually shifted T-case. I lived in Montana and Washington state and in the summer there are plenty of trails for 4x4 and in the winter it's a must. The 4x4 shift motor in my 1994 Ranger gave out I think 3 times in the course of 24 years. Also with a shift motor there is no neutral which can be a life saver if something breaks in the mountains. Not bad numbers but gave out regardless. Swapped to a manual T case from a 93 and problem solved. If you won't be spending a lot of time in 4x4 then I would say electronic shift is fine.
Thanks,
Lastly, there are rumors that Ford is bringing back the Excursion. What we do know at present, is that Ford filed a patent for that name last week, so I'm fairly certain the Excursion is about to be reintroduced in the near future.
The new for 2020 7.3L V8 gas engine added to the Super Duty truck lineup of engine choices sure is an interesting and unexpected direction for Ford Motor Company to take....
I check eBay every night I'm at work for the 7.3 Godzilla, have yet to see one, but if you could, that would be my overall choice. I'm thinking of a 78 or 79 Bronco with one. My next project perhaps
https://www.ford-trucks.com/forums/1...rt-rattle.html
The conflicting answers you are getting to those questions are likely both correct, in that to achieve a fully functioning and running 3.5 Ecoboost COMPLETELY STOCK, YES you need everything that is tied into the PCM/TCM both directly and indirectly, and hence why a written off complete truck obtained would be desirable. Just to throw another curve ball into the mix which I hadn't thought of. What if the donor vehicle is equipped with IA (a k a "push button start" in Ford lingo)? Then it's not just PATS that you would need to bypass, but also RFR and RFA as well. It more than likely is correct that it can be achieved with only the PCM/TCM, but not without out-of-factory tuning involved. As to how well such tuning will enable the engine and transmission to function to your level of satisfaction will only be known if you do move forward.
Aftermarket tuning of course, is outside my scope of knowledge since I have no personal experience with same.
Since you're interested in power train swaps, here's another thread that may interest you to read:
https://www.ford-trucks.com/forums/1...-o-pics-2.html
I know you're not a fan of oil burners, and to be honest, I have gotten beyond tired of reading those "how do I swap in a Cummins into my Ford" questions, but I have to admit, the member who did the Cummins swap into his Excursion in the thread linked above, also did a fantastic job as well. By the time he was all said and done with it, the end result appeared very turn-key, as though it came from factory that way, also sparing no time, expense or attention to detail. THAT was what really impressed me, not the kind of hack job swaps I've seen of other abortions.
