3.5 EcoBoost pretty much a direct bolt in to any 65-79 Truck
Anyone thinking of doing a 3.5 eco into any project the technology is now there to make this swap simple at a very reasonable cost vs even doing a proper rebuild on any ford v-8 along with a AOD upgrade.
Probably not any Ford platform the 3.5 eco cannot be adapted too.
1966 F250 I call Eco1
On this project i integrated the F150 dash and electronics as this being my daily driver and wanted all the creature comforts.
Since I wanted it to be able to pull 10,000 lbs safely I also used electronics for Stability Control, Trailer Sway Control, Large 14" brakes with full ABS etc
Getting close to 7000 miles since swap. Without question the best driving vehicle and most fun vehicle I have ever owned.
Its been on the drag strip, AutoCross and Road Trips (800 miles furthest so far) Its been fantastic to drive.
So anyone thinking about doing the swap into anything all I can say is go for it! 65-79 truck, 78 & up bronco etc. Drop one in your lawnmower or whatever you so chose. It can now easily be done.
With just a "Tune" I am making 420 HP and 532 lb ft of TQ at the wheels!
Under not so good conditions ran 13.03 @ 105 1/4 mile.
Did great on the AutoCross too. Just a fun daily
This one is Eco2
I have had it running but have not driven it yet.
This one is a 2015 3.5 Eco. It will be 180 deg from Eco1 with just enough electronics to make it run and drive. Just upgraded 8800 lb F250 disc brakes and a option to use the stock tire/wheel package or tire/wheel from a 2017 F250 (new truck take-offs)
Interior will be stock except the gauge package to run it all from the can bus.
Eco2 Engine is a 2015 along with 6R80 and Transfer case was donated to project.
3rd truck a complete 2015 2.7 was bought for 2350.00 plus tax and fee's.
Best off to buy a complete truck then use what is needed and part out the rest.
I have seen junkyards start around 3000.00 for a unknown engine with wiring cut and other things butchered. Some here want 6500.00 for engine and trans package. The one I looked at the PCM was sold along with other electronics.
Even if one had to pay 10k for complete truck it would be better off in the long run. Unless of course one just wants engine and trans only. Still probably better for complete truck not hit in front.
'15 & up have much better packaging . .
The whole Ecoboost line of engines are very swappable.
I have a friend that is in the process of installing one in a '70's Mercury Capri that came with a 2.8L V6.
I may also look into installing a 1.6L Ecoboost Fiesta ST engine in my 1979 Fiesta as some point.
There's a guy who installed a 2.0L SVT Focus engine in a first gen. Fiesta so the Ecoboost can be made to fit as well.
I bought 2 From Copart the other engine trans transfer case was donated by FoMoCo. (Long Story)
Mostly because of this thread
https://www.garagejournal.com/forum/...d.php?t=147380
Also here on FTE
https://www.ford-trucks.com/forums/1...oss-429-a.html
Also on YouTube
https://www.youtube.com/channel/UC9Q...iiM1Thg/videos
Doing that now! See my other threads too
Lots of info and links just posted. That should keep you busy for a while! The one thread just hit 2,410,000 views!
Check out my links to other current builds including 2 More EcoBoost Swaps.
