Bed patch
Old May 12, 2020 | 09:42 PM
  #31
resonateur's Avatar
resonateur
...so here is my cut plan. The left section in the photo will go to Hasting. It's 6" wide which should allow enough just in case the layout isn't perfectly square. I will cut on the bold black line. The right hand section will go to Mulegal and it is 9" wide. The latter section was attached to the bed brace and the spot welds were drilled out, so there will be some holes to weld where the spot weld cutter went through the bed....should be easy. I will remove the section which was cut for the gas filler lid and partially cut for another of the same. That way you don't even have to worry about that area and won't have to pay to ship it. I will split the sections with a shear on the dotted line...that should make shipping much easier and save money at the same time. You both will get the full width and edge of the floor that has the "half-rib" to join on each side. So, mulegal and Hasting, I need your addresses. Just PM me here. I'll get the pieces wrapped and, once I have your address, I'll get you an accurate shipping quote.
Old May 13, 2020 | 11:51 AM
  #32
mulegal's Avatar
mulegal
Resonateur , sent a pm hope it went. Thanks and let me know
Old May 13, 2020 | 12:26 PM
  #33
Hasting's Avatar
Hasting
Bed cut
You da man Resonateur!!! Much much much appreciated for going so much out of your way for us. I haven't been a member long enough according to the rules so I can't yet PM you. Here's my work number, just give me a ring. 352-521-4427. That's a direct line to me.
Old May 13, 2020 | 03:26 PM
  #34
resonateur's Avatar
resonateur
Will do....on both accounts. Gonna get much as I can done today. Now just gotta find some cardboard!
Old May 13, 2020 | 06:20 PM
  #35
resonateur's Avatar
resonateur
...all packed. Hasting, I missed you today but I'll call you in the morning. I'd like to get to UPS early tomorrow. Or you can email me: ehershkowitz@hotmail.com
Thanks....
Old May 13, 2020 | 07:12 PM
  #36
Hasting's Avatar
Hasting
Thanks....
You know, my phone rang once and stopped...around 3, I think.
Old May 13, 2020 | 10:31 PM
  #37
resonateur's Avatar
resonateur
...thanks...got it!
Old May 14, 2020 | 12:02 PM
  #38
resonateur's Avatar
resonateur
Mulegal....see private message.
Old Jul 12, 2020 | 10:43 PM
  #39
66 twin i's Avatar
66 twin i
Originally Posted by Crop Duster
There is an outfit in Fla. that makes a bed floor. There was a link to them in an old thread. I don't have it or remember the name. If I remember correctly it is rolled just like siding is so it doesn't have the indentations that the original has, but it did have the correct pattern.. seems like it was $750. If you do an advanced search or a google search you should be able to find them. They may have some pieces available.
Evolutionary Rides is the place in Florida. I just ordered mine last week.
Jarbl
Mar 30, 2018 12:02 PM
jack orchard
2015 - 2020 F150
Jan 22, 2018 06:40 PM
Dylanpan214
Aug 29, 2011 09:47 PM
codymoch
Jan 31, 2011 08:44 AM
